Clutch Fork Retaining Clip
Old Apr 3, 2026 | 10:19 AM
Kibbis's Avatar
Kibbis
Installing a new clutch on Frankie. It's an 04 S with the clutch fork. With the bearing off the fork slides right out so I'm getting a new plastic retaining clip. Is there an easy way to get this off before I start digging and trying to get it out?
Just thought I'd ask for any tips or quick tricks to get it.
Old Apr 4, 2026 | 05:10 AM
LukasH's Avatar
LukasH
Do you have a photo? I can't remember a plastic retainer clip. Or is it the white round plastic bush the fork goes through?
Old Apr 4, 2026 | 05:20 AM
Kibbis's Avatar
Kibbis
Yeah I may not have the name of it right, but yes that part. Looks like it's two pieces clipped together.
https://www.rmeuropean.com/Make/Mini...ch=clutch_fork
I ordered them here. Not a direct link but if you scroll down you will see the white pieces I mean. The clutch release bearing.
Old Apr 4, 2026 | 06:04 AM
LukasH's Avatar
LukasH
Pinch the two parts that stick out and push the whole thing out. The new part should just push in.
Getting the actual fork out was way more difficult when I did it as the bolt that holds the fork part to the shaft was seized.
Old Apr 4, 2026 | 06:47 AM
Kibbis's Avatar
Kibbis
Yeah my fork slid right out not even trying to remove it so I figure these are too worn. 160k so probably time to replace either way. Thanks for the info!
Acesup1090
Nov 1, 2010 05:44 AM
FastGreenMINI
52
May 5, 2009 11:32 PM
MiniJayhawk
Nov 1, 2007 11:57 AM
chava007
45
Jul 7, 2007 08:52 AM
birdmanf16
Mar 16, 2007 09:04 PM
