R56 N14 Oil Leaks - Everywhere
Old Mar 29, 2026 | 05:43 PM
SX-70's Avatar
SX-70
I've pulled the engine on my '09 Cooper S to address some oil leaks and replace the timing chain and clutch. There were obvious leaks from the front seal, valve cover, and perhaps the oil pan and oil cooler. What has surprised me is how full of oil the bell housing is. The clutch and flywheel are dry, but the starter and bell housing are saturated with oil. I'll replace the rear main seal, but I'm wondering about the two 12mm Allen head caps, are they a source for oil as well? Also, with the number and severity of the leaks I'm wondering if my engine is being pressurized by a blocked PCV.
Old Mar 30, 2026 | 12:17 PM
Rear main seal usually is all the leaks.
https://www.northamericanmotoring.co...an-gasket.html
https://www.realoem.com/bmw/enUS/sho...diagId=11_3908
I see its number 11 and 12 and not many people have replaced them. I dont see many people talking about those two allen bolts.
Old Mar 30, 2026 | 01:16 PM
Seaswood's Avatar
Seaswood
PVC is built into the valve cover usually replaced.
the oil filter housing usually turbo lines leak oil.
Old Mar 31, 2026 | 10:43 AM
Raymo2u's Avatar
Raymo2u
Those Allen caps should be tight, be sure to check and see if they are. I thought my rear main seal was leaking after replacing it while doing the clutch....only to find out those Allen caps were finger loose and pissing oil out once started.
Id replace the RMS, tighten those Caps, replace all the gaskets you can and then go from there.
Old Apr 12, 2026 | 11:58 AM
SX-70's Avatar
SX-70
Thank you for the input, I'll snug the Allen caps once I get the engine off the stand.
So far the only oil seal that isn't leaking is the head to HPFP interface. It's been discouraging.
Old Apr 13, 2026 | 03:03 PM
craney's Avatar
craney
We had to replace the allen bolts when we did the clutch - they were leaking. They come from Mini with a metal gasket/washer. There's also one facing upwards at the back of the engine block (under the air intake).
Seaswood
May 20, 2022 04:37 PM
jjcsnlynn
May 6, 2019 07:32 PM
shanksamillion
Sep 25, 2018 01:25 PM
2wheelsrbest
R60/R61 Stock Problems/Issues
Mar 26, 2018 06:09 PM
f_p
Jan 30, 2018 05:01 PM
