R55 No power to headunit or tach
Old Mar 6, 2026 | 11:49 AM
Blue Heavener's Avatar
Blue Heavener
I’m installing a complete aftermarket system with headunit and all new speakers. When I was testing my speaker wires I accidentally had the door woofer on one side touching the metal of the door and it’s sit down the headunit and tach has no back lighting. I found a couple blowin fuses and replaced them. After replacing the fuses I still have no power to headunit or tach. The fuse in the headunit wasn’t blown.
Any help would be much appreciated
Old Mar 6, 2026 | 03:03 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
What year R55?
TO 11/2008
Check these fuses:
F37 (5A): Tachometer
F21 (10A): Central Information Display (the center instrument/speedometer area), MINI joystick and radio
F34 (5A): Car Access System (CAS) - vital for providing power and data wake-up signals to the cluster
F5, F8, F47, and F48: Footwell Module - manages interior lighting and communication for the gauges
FROM 12/2008
Check these fuses:
F29 (5A): Tachometer & OBD II socket
F23 (10A): Central Information Display, MINI joystick, and Radio
F36 (5A): Car Access System (CAS)
F4, F8, F52, and F53: Footwell Module
--> At each installed fuse, use a multimeter to measure voltage at BOTH test tabs with ignition key ON. You should read ~battery voltage at BOTH tabs.
p8ntbollr
Jun 23, 2014 07:28 PM
jriechel
Jul 27, 2012 07:38 PM
StJamesG8
18
Jul 29, 2011 01:05 PM
shack01
Electrical
Feb 22, 2006 07:36 AM
vespa
Aug 4, 2003 07:48 PM
