R56 Email from mechanic... How screwed am I?
Old Feb 7, 2026 | 12:19 AM
Apollo2231's Avatar
Apollo2231
So my 09 MCS has been out of commission for a few months. Here's the timeline:
Weekend before Thanksgiving: drove about 90 or so miles to a concert in DC. Drove half way back after the concert and stayed in a hotel off the highway. Started heading back on Monday morning and got about 5 miles onto the highway and my CEL started flashing and she started misfiring something fierce. Pull over into the rest station that was thankfully within eyesight (less than a mile driven on the shoulder at about 20 mph). Call AAA and had it towed to the nearest recommended garage. They tell me it might not be looked at until the following week due to Thanksgiving. Fine. Next day they call and this is the conversation "So we ran some tests and it's definitely misfiring (duh) and we did a compression test and it's not getting almost any compression on cylinder 2. So it's likely gonna need a new engine." "Okay I doubt it. If that's the only suggestion you have then I'll have it picked up and towed to my mini specialist near me." "Well my technician is on lunch right now. He said he was gonna do some research and see if it could be anything else." "Right, I'm sure. Let me know how that goes. I'm the mean time Happy Thanksgiving."
Following week: Get a text from the garage saying my bill is due and I'm being charged a storage fee begining the Wednesday before Thanksgiving to now. Immediately call them. "What Bill? And why am I being charged a storage fee. Y'all said you'd call me if/when the technician figured anything else out." Yada yada, got the storage fee waived but has to pay $200+ for a compression test. That I could have easily done myself and told them it wasn't getting compression (matter of fact my test kit is in the trunk of the mini). And despite the fact that AAA said they do free diagnostics. Anyway. I have it towed about 30 miles to the mini specialist near me. (Mind you, I just had her in there in October to get the water pump replaced and he recommended I swap out the thermostat housing as well, which I did on my own.)
Next few weeks (December) He's a one man operation, and the only one who specializes in Minis in a 30 miles radius, so he's often booked out 3 weeks ahead. So between that and the holidays, I'm not shocked that I don't hear anything from him.
Mid January I send an email and try calling for an update, no response.
Last week I send another email because at this point I'm honestly wondering if a mini Cooper fell on him and crushed him or something. A couple days later I get this response:
So I have a couple of questions:
First and foremost. That sounds expensive. Someone tell me the explosion released the pressure and now he just has to throw on a new pcv and valve cover and we'll be ready to rock and roll. Please. I'm begging.
Second: Has anyone else ever heard of this happening??
Third: Could that be the fault of the first garage for something they did? Or I could I have messed up something with the thermostat housing? I doubt it because I really only disconnected and reconnected what felt like 100 coolant hoses, and it was running perfect fine with normal heat and pressure readings from the obdII port until the drive back from DC. When I dropped it off to them it not only started but was able to sort of drive but with no power and a violently shaking engine. Tow truck driver drove it on and off the flat bed when they came to the rest stop. And as far as I know, at least drove it on the flat bed when they retrieved it from the garage.
Here's the report from the first garage if that helps
Old Feb 7, 2026 | 01:41 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I've NEVER heard of a valve cover exploding..
our pcv dont make enough crank case pressure to do that and wouldnt the pcv cap on the valve cover had blown off 1st ???
something doesn't add up here...
or they unplugged a coilpack , cranked it alot and filled it up with so much fuel that once it caught a spark it back fired and blew it apart..
I'd get your car far away from there... something seriously wrong happened.
Old Feb 11, 2026 | 04:01 AM
mkov608's Avatar
mkov608
Concur with Adam.
To the main issue: No compression in cylinder 2. I've worked on a lot of Gen 2 MINIs, The biggest problem I've seen with no compression in a cylinder is burnt exhaust valves. These engines tend to drop valve seats too. I've also see the valve seats drop, break into pieces and get munched by the piston. Either way, the shop that performed the diagnostic deserves to get paid for their time ... even when it's bad news. You'll need to perform a leak-down test next to see where the air is escaping from cylinder 2. Bad news is you're probably going to need some major engine work to get you back up and running.
Weedahoe
Dec 6, 2022 04:59 AM
justa2010R55
Nov 29, 2022 09:02 AM
Iggy-MCS
15
Apr 26, 2006 06:35 AM
Averywo
55
Apr 18, 2006 11:27 PM
MGear
12
Sep 9, 2003 06:20 PM
