R56 Turbo coolant feed line
Old Jan 3, 2026 | 04:04 PM
302Vernon's Avatar
302Vernon
2010 R56 S
Anyone else have major leaking problems with the 90 degree elbow that connects to the bottom of the coolant reservoir tank? Seems like every time I move it out of the way to change the oil, it begins to leak and refuses to stop. You can't buy the elbow alone and have to buy the entire unit, which is like $80 or more. Any ideas or luck changing out that fitting or switching to a aluminum tank? I've replaced it 3 times in just 2.5 years. Finally got smart by replacing the plastic water pipe with a aluminum one.
Old Jan 3, 2026 | 07:21 PM
Raymo2u's Avatar
Raymo2u
I had to replace mine not long ago, this is the same hose:
https://www.ebay.com/itm/187800523024
It wont matter if your tank is aluminum or plastic, I have both and when the seal is slightly damaged, it will leak regardless. I even tried adding Orings inside the hose coupling, but that didnt do much of anything.
Old Jan 3, 2026 | 08:11 PM
302Vernon's Avatar
302Vernon
This is the one for my year and model. But i only need the plastic fitting or to modify it to eliminate that weak 90 degree elbow.
Old Jan 4, 2026 | 10:40 AM
Raymo2u's Avatar
Raymo2u
This is the cheapest Ive seen for the N14 return
https://ebay.us/m/iA4JQG
Old Jan 5, 2026 | 11:25 AM
white46's Avatar
white46
I just had this issue and was able to replace the plastic T connector with brass from HomeDepot. $5 and 3 hose clamps.
1"*1"*3/4"
For more information,
https://www.northamericanmotoring.co...rt-number.html
Old Jan 5, 2026 | 11:29 AM
+1 get the upgraded T or a line that has it.
https://www.northamericanmotoring.co...onnection.html
People that just have a bad O-ring. We have the end piece also now under bremmen.
airbusA346
Feb 18, 2025 05:46 PM
Emincee1012
Jul 12, 2017 12:10 PM
BigGar
Apr 24, 2017 05:17 PM
Snake20
Aug 29, 2013 11:11 AM
guitfiddler
Oct 11, 2009 03:17 PM
