R56 OEM Xenon bulb looks purple/violet
Old Dec 28, 2025 | 04:15 PM
Lex2008's Avatar
Lex2008
Hey guys,
Should I assume this color change on the passenger headlight means the bulb is about to die-skies? The pic doesn't show it but it looks very violet colored.
Old Dec 29, 2025 | 03:38 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If they are the original HID bulbs from 2008, then I would bet they could use replacing
Old Dec 29, 2025 | 05:39 AM
Lex2008's Avatar
Lex2008
I asked the original owner... Apparently they are the original xenon bulbs which explains the color change. Age
OE Sylvania are $37 each on rock auto as opposed to over $100 on fcp euro and ecs "tuning*.
Old Dec 29, 2025 | 06:16 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I ran all different type of bulb in my old Clubman, and the best output were from high quality OEM spec bulbs. The ones on RockAuto are likely counterfeit China bulbs. The cheap bulbs will have good alignment inside the projector, and will not have great output. If you do any kind of night driving, you'll notice it right away. Buy from a reputable source, not RockAuto or Amazon, unless you really don't care.
If you want cheap / inexpensive, these are probably going to be a slightly better choice:
https://www.theretrofitsource.com/d1...D1S?quantity=1
Old Dec 29, 2025 | 06:30 AM
Lex2008's Avatar
Lex2008
Last time I check Rock Auto didn't sell anything counterfeit. That would be a reputational disaster for them. They do sell lots of crappy stuff and OEM manufacturer stuff but not counterfeit.
Where did you get his info?
The link to the brand u posted is the same price as FCP Euro and ECS which sell Sylvania OSRAM.
Old Dec 29, 2025 | 06:56 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Go for it then. I’d be hesitant to order those from RockAuto. Their cost is half compared to anywhere else. That triggers my pucker warning…
Old Dec 29, 2025 | 06:58 AM
Lex2008's Avatar
Lex2008
Yes I admit its quite a difference.
Ill report back.
Old Dec 29, 2025 | 07:02 AM
Lex2008's Avatar
Lex2008
https://www.osram.com/am/the-trust-program/index.jsp
https://www.youtube.com/watch?v=nQdomS_YH4o
Old Jan 3, 2026 | 11:56 PM
MiniBOL's Avatar
MiniBOL
I bought these from TRS over 8 yrs ago and haven’t had any problems.
Old Jan 4, 2026 | 06:18 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Could be a bad bulb or excess resistance either in the power side or ground side of the right circuit. For example, is voltage at the right passenger connector lower than at the left driver connector under load? Your LoadPro tester would be useful for this potential issue.
Another afterthought idea would be to swap the bulbs to see if the color differences follow each bulb.
Old Jan 6, 2026 | 07:57 AM
Lex2008's Avatar
Lex2008
wow those are bright!
I just received the Sylvania D1Ss from Rock Auto
OSRAM product in Sylvania box but not way to check for authenticity.
but in this video he had my same experience when ordering through autozone:
http://​​​​​​​https://www.youtube.co...?v=vqb__y4dOBI
Old Jan 6, 2026 | 08:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Install them and see how they work. Based on beam pattern, you should be able to tell pretty quick if they are legit or not.
Old Jan 6, 2026 | 08:12 AM
We have these now, thats my next upgrade if the factory bulbs go pink.
https://www.ecstuning.com/b-ziza-par...3452lb04-01~a/
I just did the Xenon to LED Ziza bulb/ignitor only upgrade on my Rover with factory xenon and its night and day on output going to led. Took a whole 10 mins to change them out.
Old Jan 6, 2026 | 08:17 AM
Lex2008's Avatar
Lex2008
They are legit me thinks..just high volume factory-installed bulbs, as the guy states, which sell for much less.
The right side bulb just burned out this afternoon. Glad I have new bulbs on hand.
Old Jan 7, 2026 | 08:08 AM
Lex2008's Avatar
Lex2008
Im completely uninterested in LED retrofit bulbs. Those housings were developed with XENON's in mind and just because something is LED doesn't mean its brighter, better, or will last as long.
That being said:
Old Jan 7, 2026 | 09:16 AM
The flap for the Bi -xenon has the correct cut off and will not blind/glare, its when you put LED with no cutoff in a halogen headlight reflector with non focused light - then your lifted truck LED type blind. I would not do that. ON the MINIs and Rovers you are fine as they are designed to take the fixed LEDs we have. They have a focused pattern with cutoff and the lens that's focused.
Xenons are good for a while until they get the pink death.
Old Jan 7, 2026 | 09:20 AM
Lex2008's Avatar
Lex2008
Dude the OEM bulb lasted almost 20 years. I GUARANTEE the LEDs you sell wont last that long.
Old Jan 7, 2026 | 09:28 AM
Thats pretty good! My factory xenons R58 lasted lit 7-8 years. On the R52 with the d2S they lasted 5 years, the actual end of the bulb were the small wire meets the tiny filament on top of the Xenon gas tube failed and it was OSRAM factory. They get brittle with heat cycles and the ride on the R53/R52/R50 have a much tighter suspension and seems to break those bulbs over time. Maybe a combined factor.
Old Jan 7, 2026 | 09:33 AM
Lex2008's Avatar
Lex2008
I have another car with OEM xenons since 2007.
I know you guys wanna sell stuff but....
Old Jan 7, 2026 | 02:40 PM
Lex2008's Avatar
Lex2008
This tool made it pretty easy to unplug and plug in the new bulb.
Old Jan 8, 2026 | 03:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Glad the new bulbs fixed it up for you!
What most people fail to accept is that HID bulbs do have a life span. As they age, they get dimmer. Even though they light up, they lose brightness slowly over time. Most people think “they are light up, still good!” HID bulbs should actually be replaced every 5 years to maintain brightness.
Old Jan 8, 2026 | 05:54 AM
Lex2008's Avatar
Lex2008
I agree.
Some are easy to access like the r56, some require more effort
Old Jan 8, 2026 | 03:32 PM
MiniBOL's Avatar
MiniBOL
Glad it worked out for you.
Just got these today as an experiment to see how LEDs would look and work compared to HIDs.
Old Jan 8, 2026 | 03:34 PM
Lex2008's Avatar
Lex2008
Will they fit? Will the cable reach?
Old Jan 8, 2026 | 04:06 PM
MiniBOL's Avatar
MiniBOL
Haven’t had a chance to look but they’re D1S housing so they should fit. It should be plug and play using the OEM plug.
