Suspension Better spring than Eibach Prokit for daily?
Old Dec 23, 2025 | 09:07 AM
R57dropstick's Avatar
R57dropstick
So I recently bought a 13 Cooper S convertible with Rotiform 17" wheels and the prior owner said he had installed lowering springs years ago. It seems a little too low for me, but it could just be due to the fact these cars already appear low. It seems a little too "bouncy" for me and it doesn't do to well with the dips and bumps we have here in western NC. I just jacked it up and found it to have Eibach Prokits and stock shocks. I was already planning on getting Bilstein B4's for sport suspension as the lower bushings are worn and cracked on the stock shocks (71k miles). Is there a "better" lowering spring- I've seen H&R and Neuspeed. Both seem to drop it 1.2" f/r. Thanks for any help. I don't want to spend coilover money if at all possible. I have to replace the worn upper camber arms (M7- ends have slop and are 7 years old) as well as rear brakes and the left inner tie rod end.
Old Dec 23, 2025 | 11:27 AM
hello,
Bet the factory shocks are on their way out if its bouncy. Bilstein B4' would be an easy swap and i would do the upper mounts all around. Thats about the average drop for MINIs
Old Dec 23, 2025 | 12:58 PM
R57dropstick
I just ordered new B4 sport shocks, upper front mounts, rear shock bushings, wipers, rear brakes, floormats, left inner/outer tie rod ends, and M7 rear camber arms with poly ends from ya'll just a few minutes ago. I called it in to get my veteran discount and I appreciate that! The left inner tie rod had play in it, rear lower shock mount bushings were cracked, rear rotors severely grooved.
06minirube
Suspension
Jun 9, 2020 06:29 PM
jwreichle
Suspension
Dec 12, 2015 08:31 PM
Maybe
Jun 7, 2015 01:56 PM
USCooper
Suspension
Dec 17, 2013 07:40 AM
Mini-ARG
Suspension
May 29, 2010 09:51 AM
