R56 DIY replace TPMS wheel sensors?
Old Dec 10, 2025 | 01:13 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Has anyone done this job at home?
I'm considering buying this
bead breaker bead breaker
and these
wheel sensors wheel sensors
Opinions and advice would be appreciated.
Old Dec 10, 2025 | 03:14 PM
Maybe, maybe not
Community Builder
I currently have no RDC fault codes or TPMS warning light, but I think the batteries in the TPMS sensors are weak based on these live data:
Old Dec 23, 2025 | 12:15 PM
Maybe, maybe not
Community Builder
Maybe I'll try building one of these bead breaking tools using some scrap wood.
Old Dec 24, 2025 | 10:00 AM
Jawa's Avatar
Jawa
Front ABS Wheel Sensors
Just replaced both front ABS sensors on 2013 R56 N16 Base model Mini Cooper. Was getting a variety of different codes on OBD II reader. All they are is an allen screw and 2 wire blue harness that unplugs
Old Dec 24, 2025 | 11:00 AM
Maybe, maybe not
Community Builder
Depending on the year & model, MINIs use one of two different approaches to detect low tire pressure and flats: (1) tire pressure readings sent to the RDC (tire pressure control module) from pressure sensors located in the four wheels (TPMS) or (2) circumferential wheel speed readings sent to the ABS-DSC control module from the four ABS wheel sensors (FTM).
My 2012 MINI uses approach #1. If your 2013 MINI lacks tire pressure sensors, then ABS wheel sensors are used to detect low tire inflation or flats.
mlee4984
Mar 9, 2019 08:42 PM
JT///MC
Aug 20, 2013 06:20 AM
pmsummer
Jun 10, 2013 04:15 AM
k_h_d
May 27, 2013 10:35 AM
