Added another JCW to the group - R60
Old Nov 9, 2025 | 06:15 PM
MiniConn's Avatar
MiniConn
Just picked up a '15 R60 JCW this weekend. On way home got the 2C57 code 😒 I've read this code can be caused by the diverter valve being bad, wastegate actuator, etc.
Pulled it apart today to investigate. Intake tube was broken at PCV connection, but I don't think that has anything to do with it just something that needs replaced. I removed the diverter valve and I don't know what to look for so just ordered a Turbosmart replacement. We run it on our R58 JCW and it sounds good.
Tested wastegate actuator movement with a vacuum pump next. Watched the movement and it doesn't fully close wastegate until 15 psi of vacuum. The locknut was about an inch from the wastegate so clearly I have found the issue and reason for lack of boost.
My question is, at what psi of vacuum should the wastegate be fully closed? I've read 5-10 but wanted to make sure before you put it in service mode and get after it.
Thanks in advance!
Old Nov 10, 2025 | 06:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I think the wastegate test vacuum is ~15". At least, that's what I've seen in a few places for the OEM wastegate. If at 15" the wastegate isn't closed, then that would be the source for your code.
Turbosmart makes an aftermarket replacement wastegate, and makes a comment about the internal spring having influence on the vacuum required for closing. Their wastegate vacuum is ~6".
https://support.turbosmart.com/porta...tance_Plumbing
Old Nov 10, 2025 | 12:05 PM
MiniConn's Avatar
MiniConn
Actually have one sitting on the bench to install on our R58! Just haven't decided when I want to tackle installing it
Old Nov 11, 2025 | 02:39 PM
MiniConn's Avatar
MiniConn
Update: wastegate nut was backed off all the way! Now I'm trying to adjust it, at what HG should it start moving? I have it set at 8hg now, but at 15hg the wastegate doesn't seem to be fully open.
Old Nov 12, 2025 | 06:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
OEM wastegate, correct? It should be fully open at zero vacuum, and fully closed at 14-15" vacuum.
Old Nov 12, 2025 | 10:38 AM
MiniConn's Avatar
MiniConn
Correct, OEM wastegate. OK good I set it to fully close at about 13-14 HG. Nut was completely missing on the closing side of rod, the lock nut on actuator side was spun all the way to rod. This picture was after I spun it several turns. No wonder this car felt slower than crap!🤦🏻‍♂️ I have no idea how previous owner drove it every day and "didn't notice" hahaha
Wastegate actuator
Wastegate actuator
Old Nov 12, 2025 | 10:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Holy Moly! Glad it was an easy fix. I wonder if they sold it because it started feeling off power...
Old Nov 13, 2025 | 02:06 PM
Nice fine on a rare R60 almost last year JCW, those things are sweet. Glad to find an easy fix.
Old Nov 13, 2025 | 08:50 PM
MiniConn's Avatar
MiniConn
I drove it 3.5 hrs home like that, it was gutless for sure!
willeh
Mar 31, 2025 12:57 PM
ridler
Jul 17, 2022 08:29 AM
Cenla Mini
Jun 26, 2020 11:59 PM
7rhSon
Dec 11, 2019 12:16 PM
jacknk
Jun 2, 2017 07:38 PM
