R56 Mystery engine block plug at rear of engine
Old Oct 26, 2025 | 10:07 PM
craney's Avatar
craney
Does anyone know what the plug marked with a red arrow is called? I've got the intake off the car and can see that mine is leaking, but I don't what sort of seal to get 😕
N14 engine on R56 Cooper S.
Back of N14 engine with a plug marked.
Old Oct 26, 2025 | 10:27 PM
craney's Avatar
craney
Found it! http://minifans.info/parts-catalog/R...ock/#7558633_9
Old Oct 28, 2025 | 01:07 PM
Yep taht looks like it https://www.ecstuning.com/b-genuine-...117558633~oem/
Old Oct 28, 2025 | 07:03 PM
craney's Avatar
craney
I just picked it up from the local MINI Garage here in Canberra... will fit it today. AUD$14, and they looked up the torque spec for me (30 Nm). :-)
PS I look it up on ECS, but the shipping to Australia for a cheap part is a lot...
Old Oct 29, 2025 | 05:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
FYI, the oil drain plug will fit there.
Old Oct 30, 2025 | 11:05 AM
Raymo2u's Avatar
Raymo2u
Just a heads up to those who are doing a clutch or have their trans off, make sure 2 of the same type of plugs behind the flywheel are tightened!
After finding out my clutch plate was put in backwards on the first go, the second time I put it back together - I had oil leaking out of my trans when I started the car. The same type of plugs were finger loose and draining oil. Its alot of work to go through just to get to them and tighten them up, so if you are in there be sure to check them!!
Uli
May 29, 2024 05:15 PM
Lex2008
Aug 21, 2023 08:54 AM
Derek Chung
Jan 30, 2023 07:33 AM
trlman
Factory JCW Talk (2009+)
Dec 5, 2022 12:43 AM
