R56 Low Pressure Fuel Line Stuck - I've buggered it - what to do?
Old Aug 12, 2025 | 09:40 AM
David.R53's Avatar
David.R53
Hoping for some advice here - I was doing some work on my kids car and tried to remove the low pressure fuel line. I have the "special tool" but it didn't work and poking the tabs with two small screwdrivers seems to have just destroyed them. Won't come off. I've already given up on reusing it and have a new one, so the question is how to get it off without damaging the pricey high pressure fuel pump? It spins freely so I could cut it all the way around. A little queasy about running a cutting tool near the gasoline supply... (I have removed the far end)
Any tricks?
Low Pressure Fuel line connection R56/R55
The little tabs are buggered...
Old Aug 13, 2025 | 07:40 AM
mkov608's Avatar
mkov608
From your picture, the quick disconnect fitting is screwed into the HPFP. I wonder if you would be able to unscrew the QD fitting from the HPFP.
MinimooCa
Jan 22, 2024 07:53 AM
thebombardier
Dec 24, 2023 04:09 PM
jcslocum
Sep 23, 2023 11:57 AM
JannerSy
General Discussion
Apr 20, 2022 10:31 AM
JoelDB44
Jul 15, 2016 10:27 AM
