R50/53 Rear hatch lock not unlocking
Old Jun 19, 2025 | 08:30 PM
machi_dev's Avatar
machi_dev
Every time I think I know what the issue is, it turns out to be something else. I’ve confirmed it’s not the button on the lid, or the lock itself, the lock just not receiving a signal when it should. When I press the hatch button on the key. the lights blink twice on the vehicle but no voltage is applied to the line. There’s 4 pins, I haven’t been able to figure out what does what. I’m not sure if the cable is damaged somewhere, but I’m also not sure how to check. I can’t find any information on where it connects, or the easiest way to access that connection. I’ve checked all the fuses. I can’t find any unlock it via the mechanical release under the seats.
Any advice is welcome I’m stuck.
Old Jun 24, 2025 | 07:19 AM
Fradow's Avatar
Fradow
The wires connect to the BCM. Here's a link where the pinout of the BCM is listed: https://www.minitorque.com/threads/t...trol-unit.557/
The BCM is situated on the passenger side (for LHD cars, driver for RHD cars) behind the trim around the hood release handle.
If I had to guess, it's likely your BCM was flooded, which is a common issue especially on Minis with a sunroof.
The manual mechanical release under the seats is not fitted on all Minis. I think it only started being fitted during 2003, but I'm not 100% sure of that. It's an easy retrofit though, and one I really recommend doing to get out of sticky situations (for example both doors frozen shut, or any "loss of power" event).
machi_dev
Jun 20, 2025 02:14 PM
Yazon
Oct 12, 2015 06:51 PM
silence2-38554
Jul 9, 2015 05:24 AM
cur
Mar 12, 2008 03:38 PM
early_apex
Feb 4, 2004 09:03 PM
