R56 n12 misfire
Old Jun 9, 2025 | 05:34 PM
Rh1988's Avatar
Rh1988
R56 n12 misfire
Hi guys im in some serious need of help i bought a 2010 mini cooper base r56 it had misfire codes for cylinder 1 found it had a cracked exhaust valve in cyl.1 lapped new valves in the head did timing chain kit new headgasket pistons and cylinders looked in good condition new thermostat housing the guy i bought it off did new injectors coils plugs and cam sensors. while i was doing motor i did entire color change the car ran fine around the shop just finished reassembly and took for first road test and im right back to my beginning point other than the car looks new lol misfires in cyl.1 codes are 2772, 2773, 2782, 2783 im very bummed out had this posted in the wrong section so i figured i would move it here
Old Jun 12, 2025 | 05:04 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Swap cylinder 1 and cylinder 2 (or cylinder 3 or cylinder 4) spark plugs. Do cylinder 1 misfire codes move to new cylinder? Do same for the cylinder 1 coil.
Old Jun 12, 2025 | 08:34 PM
Rh1988's Avatar
Rh1988
have moved everything all over still cylinder 1 for the most part a few on cylinder 3 aswell
Old Jun 13, 2025 | 05:35 AM
Maybe, maybe not
Community Builder
Fuel injectors too? If so, compression test the cylinders.
Rh1988
Jun 9, 2025 12:44 PM
rob71charger
Jun 7, 2024 04:36 PM
Mike_R
Dec 12, 2023 06:07 AM
SlothsRUs
May 1, 2019 04:34 PM
