R56 Fuse Box diagram?
Fuse Box diagram?
Does anyone have a schematic of the fuse box itself? Chasing electrical issues and the ECU has tested good, the affected sensors are all replaced and no shorts to ground in the harness. Waiting for the ECU to return to test shorts for power, but I started digging into the fuse box but I'm not knowledgeable enough without a diagram.
With all the fuses removed, a couple of the DME fuse pins have continuity to multiple connector pins on the underside, and one of the fuses doesn't have any continuity to anything. Not sure if this is normal or not
