R56 Replace Oil Filter Housing Gaskets WiTHOUT removing Cat?
Old Mar 13, 2025 | 06:24 PM
walk0080's Avatar
walk0080
When I had a hole in the exhaust flex pipe some time ago, turns out the indi muffler shop welded a new one to the old cat... I don't currently have a clamp between the flex pipe and the catalytic converter. So must cut the weld, or wait until I can get a proper clamp setup.
Has anyone been able to replace the oil-side gaskets on the oil filter housing / oil cooler on an R56 S/JCW without removing the cat? I don't need to work on the turbo oil feed or return lines... and so don't need to remove the heat shield from what I understand.
Old Mar 18, 2025 | 09:31 PM
white46's Avatar
white46
I just did this a month ago, and it's impossible to do without removing the CAT. It must be removed.
Old Mar 19, 2025 | 11:37 AM
Yea, its in the way and you have to remove the cat and those shields.
Here is the trusted DIY:
https://www.northamericanmotoring.co...ispreloading=1
Old Mar 19, 2025 | 06:49 PM
minifanboy's Avatar
minifanboy
Here is a great visual guide as well. It's a N14, not N18, so it's not identical. But a great breakdown nonetheless.
mbwicz
How to
324
Jan 26, 2026 06:22 AM
whoanelli
R58 :: Coupé Talk (2012+)
Jun 8, 2021 06:28 AM
7rhSon
May 20, 2019 06:37 PM
JAB 67
Aug 8, 2018 04:45 PM
fifty9singlecab
15
Nov 15, 2012 09:17 PM
