Clutch slip - clutch replaced 10k miles ago
2006 Mini Cooper with clutch slip issues- clutch replaced 10-15k miles ago
The clutch was replaced about 10-15k miles ago with a LUK kit (clutch, pressure plate, throw-out bearing) and a new flywheel. We didn’t replace the rear main seal at that time.
Symptoms:
• Clutch engages high.
• Slipping in all gears — e.g. In 2nd gear, pressing the gas causes the engine to rev without increasing speed.
- Has anyone seen clutch to wear out this quickly?
- Could a leaking rear main seal cause oil to contaminate the clutch and lead to slipping?
- What else should I check? Could it be a faulty slave cylinder, clutch adjustment issue, or something with the flywheel?
Any insights or thoughts would be really helpful. Thanks!
Symptoms:
coop2country
27
Mar 18, 2019 03:41 PM
fwtcc
11
Jun 9, 2009 04:41 PM
