R50/53 Custom R53 Boost Gauge
Old Jan 28, 2025 | 05:38 PM
TBITZ's Avatar
TBITZ
I'm working on a boost gauge for my R53. It features a red needle that sweeps from vacuum to 20psi boost. A yellow tell tale needle follows and holds at the highest boost reached and slowly decays after 1minute. The intake air temperature is also shown.
Right now it's in simulation mode, but plan is to tap into the signal from the boost sensor on the manifold to pickup the boost and air temperature and process it.
Old Jan 30, 2025 | 02:55 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I like it.
Any chance you can make it available to match the original factory gauge aesthetic?
Old Jan 30, 2025 | 03:28 PM
TBITZ's Avatar
TBITZ
The enclosure is 3D printed, so could get a chrome air vent bezel and 3D print an adaptor to fit the gauge inside.
Old Jan 30, 2025 | 04:01 PM
TBITZ's Avatar
TBITZ
I uploaded a video showing how the gauge dials would work.
Boost Gauge Video
Old Jan 30, 2025 | 08:15 PM
cooper48's Avatar
cooper48
I like it. How is it being calibrated?
Old Jan 31, 2025 | 05:41 AM
TBITZ's Avatar
TBITZ
I will manually read the pressure and temperature off the OBD2 port and use that to set the slope/offset curves inside the boost gauge.
Old Feb 2, 2025 | 10:23 AM
TBITZ's Avatar
TBITZ
Fabricated a gauge POD that bolts to the back of the tach. The display is in simulation mode powered by USB until it gets wired up to the cars wiring.
Old Feb 3, 2025 | 01:34 AM
LaurenCollins's Avatar
LaurenCollins
I like it is a great project! I'm excited to see progress!
Spoiler
Old Feb 11, 2025 | 04:31 AM
OliviaScott's Avatar
OliviaScott
How is everything now?
Old Feb 11, 2025 | 10:36 AM
TBITZ's Avatar
TBITZ
I've fished a 4 wire cable from the TMAP sensor on the intake, into the cabin and into the gauge pod. There was a spot on the driver side that goes through the firewall near the brake reservoir. Some pics below.
cable needs to be spliced to TMAP sensor wires
Old Feb 14, 2025 | 02:37 PM
TBITZ's Avatar
TBITZ
I've searched for the datasheet of the TMAP sensor used in the R53, but no luck. I did find a datasheet for a similar sensor that has a table of thermistor resistance values vs temperature, and an equation for the pressure vs voltage. My guess is the thermistor is going to be exactly the same. The constants for the pressure sensor will need to be adjusted.
Old Feb 14, 2025 | 02:43 PM
TBITZ's Avatar
TBITZ
There is also a recommended circuit in the datasheet, that I wonder if MINI used in the R53. Would need to know the resistors MINI used to connect to the thermistor to come up with an equation for temperature vs voltage. Below they show a 2.61kOhm and 38.3kOhm with the thermistor connected in the middle. Not the end of the world if this isn't available, can reverse engineer it from a couple of temperature readings from the OBD port.
Old Mar 15, 2025 | 04:20 PM
TBITZ's Avatar
TBITZ
Had some nice weather today, so proceeded to wire into the TMAP sensor. This was very painful. Its very difficult to push out the existing pins on the 4 wire connector. I cut off the old pins once they were pushed through, fed through 4 new wires and crimped them on the existing wires with new crimps. Some pics below.
TMAP connector in original state.
Pins finally pushed out the connector housing, and 4 new wires fed through.
new and old wires put in parallel with new crimps.
TMAP connector back on the sensor. A couple tie wraps to strain relief the new cable on the old cable.
Old Mar 31, 2025 | 12:47 PM
TBITZ's Avatar
TBITZ
In order to get accurate data for the gauge, I decided to remove the TMAP connector from the sensor and feed a voltage into the temperature and MAP wires and read the OBD2 values. The plots below show the transfer functions. For MAP it's a linear relationship. For temperature sensor I used a 5th order polynomial to get a very accurate fit.
Old Apr 2, 2025 | 12:50 PM
TBITZ's Avatar
TBITZ
I installed the boost gauge for some testing. Link below is a pull showing both boost gauge and UltraGauge via OBD2.
https://www.dropbox.com/scl/fi/2hxz6...=wbf8ruj1&dl=0
The response of the boost gauge needles, and air temp is responding in realtime which is a big improvement over the slow updates of the UltraGauge.
frankiev
Dec 10, 2021 06:21 AM
Mini_Chan
Mar 11, 2017 03:52 PM
traden86
Dec 14, 2008 09:09 AM
MSFITOY
Jul 4, 2006 12:29 AM
