Aux gauge oil/water sending unit locations
I’d like to add electrical gauges for oil pressure, oil temp, and water temp to my 2009 r55 Clubman S. Are there any spots on the engine that are easier to get to for adding sending units? My first thought is to look at the oil filter housing to see if I can get a T inserted for oil temp/pressure, and then coolant either coming out of the head or out of the radiator. But I thought I’d ask here first to see if there is a better solution.
This is the install for the water temperature adapter:
https://www.cravenspeed.com/water-te...de-mini-gen-2/
Here is an install for N14 oil pressure adapter:
https://www.cravenspeed.com/tapless-...2-pre-refresh/
Interior/Exterior Aftermarket OIL temperature gauge
William Blake
Nov 25, 2008 11:07 AM
Drivetrain Water temp and oil pressure gauge help
MSFITOY
Aug 2, 2004 02:50 PM
