R56 Replacing Cooper's battery
Old Jan 15, 2025 | 04:09 PM
redwhiteR562007's Avatar
redwhiteR562007
2007 R56 Hatchback.
Very cold here, very slow cranking, checked battery, it's five years old, local NAPA will have one tomorrow.
As I recall, after replacing the battery, there is some sort of a reset routine required???
If so, what do I do? Been a long time.
Now that I think about it . . . there may be a function on my code scanner -- select BMW as the vehicle, wait until it reads the VIN, then there may be a selection to reset battery. Sound familiar?
Thanks.
Old Jan 15, 2025 | 07:16 PM
bluonyx's Avatar
bluonyx
Sounds right, if you have the negative cable like the attached pic then you'll have to code the new battery to your Mini. Just had to do my R58 and F60, two batteries in two months, I shouldn't really complain. I got 10yrs out of the R58 batt and 7yrs from the F60.
Old Jan 17, 2025 | 09:13 AM
maccoder's Avatar
maccoder
There are two separate procedures:1. Coding - required if your new battery has different characteristics compared to the one you are replacing.2. Registration - required if your cable has IBS as mentioned above by @bluonyx.
Old Jan 17, 2025 | 09:31 AM
bluonyx's Avatar
bluonyx
Yup, Bimmercode then Bimmerlink.
Old Jan 17, 2025 | 09:36 AM
z168's Avatar
z168
Lucky my 2013 base doesnt need coding. Straight swap.
FWIW, Ive been lucky with using genuine Mini (and BMW) batteries. Replaced the battery on mine in 2018 and its still going (hope I dont jinx myself)
David MacNeill
Jan 6, 2022 09:15 PM
JDPaddle
Feb 28, 2021 03:35 PM
rtbship
Jan 24, 2017 01:47 PM
ahurvitz
Mar 30, 2016 09:57 AM
Birdman
Mar 23, 2012 10:16 AM
