R55 R55 manual Clutch replacement
Old Jan 10, 2025 | 06:33 AM
Statesman's Avatar
Statesman
OK hi all!
My clutch is starting to slip and it's time after 115k miles for a clutch replacement.
I unfortunately can't do the work myself so wondering if anyone can give me some guidance on estimated costs (part seems to be around 550$), how many hours of labor is it really to do a replacement?
I got quoted 3500$ with 15 hours of work? Is that reasonable or should i keep shopping around?
Old Jan 10, 2025 | 06:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
A solid budget would be ~$1,000 for parts and about ~$1,500 for labor.
You will want to replace the clutch kit (disc, pressure plate, release bearing), flywheel, flywheel bolts, clutch release lever, rear main seal, both axel seals at a minimum. A nice to replace while you're in there would be an LSD. But if you are not doing the work, that will add significantly to the cost since the gearbox will need to be opened up.
Old Aug 2, 2025 | 06:41 PM
JihooDad's Avatar
JihooDad
Just got finished doing this for my daughters car. 2009 r55 base (116k...original clutch and flywheel dated 2009 on removal) First and foremost F^*K RockAuto! They only sell the longer 25mm bolts that are to be used on a DMF. The solid flywheels require the 20mm hex bolts! How do I know? Cause they sold me those 25mm bolts and I installed them. Then I had to rip it all apart and put the shorter ones in. Flywheel was frozen and i burnt a starter finding out! Essentially did 2 clutch jobs. Saturday and Sunday gone! lol
I don't know where you are located...but I called around the cheapest I found was $1500 + parts. It's a $2500 job easy if you choose not to do it yourself. It was actually not that difficult...time consuming...but never really broke a sweat....except for that damn tie rod that didn't want to move....MAP gas to the rescue!
Old Aug 2, 2025 | 07:28 PM
Statesman's Avatar
Statesman
Hey all
Odd fix... But it worked...
I'll note I had significant slipping and honestly thought my transmission was boned...
I had a garage change the transmission fluid. (Something against the mini Cooper guidance as they say the transmission fluid is good for life in a manual transmission)
This actually almost entirely solved my issue or at least punted it down the road. 120k miles and still going on original parts.
Old Aug 3, 2025 | 09:38 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Originally Posted by Statesman
Hey all
Good luck! I hope it lasts.
Gmharrison
Feb 3, 2017 12:51 PM
911***
Sep 12, 2016 06:12 PM
PatM
Sep 11, 2012 05:59 PM
CalvinC
Mar 15, 2011 09:58 AM
