R50/53 Header replacement
Old Nov 12, 2024 | 11:03 AM
TomJey's Avatar
TomJey
Header replacement
Hi everyone,
The header on my 2003 MCS has separated into two parts, so I'm looking for replacement options.
Here’s what I’m hoping for in a replacement:
  • California SMOG compliant: Header needs to avoid triggering any codes that would prevent smog approval
  • Fitment: Something that fits without modifications, like enlarging fastening holes etc
  • Cat: I’d like to avoid having to weld a catalytic converter to the header.
  • Price: Looking for an affordable option since I'm mainly after a replacement. Performance gain would be great, but ok if not.
I’ve looked into headers here on the forum, but it seems California SMOG compliance really limits my options.
On a different note, the car has around 190k miles and has been all over the US, so I’m a bit concerned the header screws might be tough to loosen. Any tips for dealing with that?
And if anyone has a used header for sale, please let me know : )
Cheers,
Tom
Old Nov 21, 2024 | 08:33 PM
Racingguy04's Avatar
Racingguy04
Mine did this a few years ago, I was able to get a shop to weld it back together for less than $100. They didn't have to remove the header or anything. Mine failed because my motor mounts had failed, so you might want to check yours.
Old Nov 27, 2024 | 05:06 PM
Ministrater's Avatar
Ministrater
Revolution Mini Works shorty header will not code and fits right in.
Like dude above said, a competent exhaust shop should be able to weld yours back together. I had that done once before at a custom exhaust shop.
Old Nov 27, 2024 | 05:16 PM
noodlesandsam's Avatar
noodlesandsam
CARB compliant - Original Mini only. Big $. That is the only one I have found. $1700 for the one in an Auto - $2800 for one in a manual. Cali does not want to see welds - that will likely fail a visual inspection.
Old Dec 1, 2024 | 08:16 AM
junits15's Avatar
junits15
Is it possible to get a standard catless or sport cat header of your choosing and then have a shop cut and weld your old OE cat into it? That would make it pass the sniffer test and potentially save a bunch of cash. Sucks that such an old car is still required to pass
Old Dec 1, 2024 | 09:53 AM
ghostwrench's Avatar
ghostwrench
WTH? Seriously?? What difference does it make if there are welds as long as what comes out of the pipe is clean?
Old Dec 10, 2024 | 05:34 AM
JoshuaCamacho's Avatar
JoshuaCamacho
You are right, I agree with you.
Old Dec 11, 2024 | 05:10 AM
JonathanWard's Avatar
JonathanWard
Replying for the updates.
Old Dec 11, 2024 | 10:44 AM
Boostmaster's Avatar
Boostmaster
If this is going to be a CA car, I would recommend buying a used header and call it good. If the inspection site sees ANYTHING that does not look factory they will likely fail it. (ask me how I know)
Old Dec 19, 2024 | 09:53 AM
Tombstone's Avatar
Tombstone
I live in So.California and my regular smog guy said that visual welding or even upgraded supercharger pulleys will not flunk the bi-annual smog checks…
Old Dec 19, 2024 | 01:57 PM
Here2Go's Avatar
Here2Go
NAM Community Team
It amazes me - Due to the rash of catalytic converters being cut out/stolen; that a smog inspection sites would see welds as commonplace these days(?)
Old Dec 19, 2024 | 04:44 PM
Tombstone's Avatar
Tombstone
Had two CARB approved Magna Flow cats blow out (back-fire) , due to a bad fuel injector and they were both cut-out & welded in on my Transam GTA . No problem …
Barnabas
Want to Buy - All Other Items (archive)
May 26, 2008 01:59 PM
SpiderX
Jul 30, 2007 09:27 AM
MassMiniac
Mar 28, 2006 08:07 PM
TonyB
Feb 18, 2005 01:18 PM
acotam
Jan 23, 2004 06:48 PM
