R60 radiator fan problem
Old Oct 31, 2024 | 12:59 PM
enzo972's Avatar
enzo972
Hello everyone,
I have a mini one countryman from 2012 model R60 98hp automatic gearbox.
I had white smoke coming out of the hood and I noticed a fluid leak from the thermostat box. So I changed this box with the probes, I filled the coolant, purged it etc.; I went for a walk, and noticed that the fan doesn't turn, even when I turn on the air conditioning.
I then tested the fan directly, it works well. I also tested all the engine compartment fuses and relays, they are all ok.
Can you help me please?
Thanks for your help.
Sorry for my little english, i'm from Martinique, french island..
Old Dec 4, 2024 | 01:34 AM
supazuk's Avatar
supazuk
Originally Posted by enzo972
Hello everyone,
Did you bleed the system via the bleed valve on the thermostat if not air in the system will not allow the to read the coolant properly. It could also be the switch itself (test by checking resistance cold and hot)
PJ Wooter
Mar 12, 2024 05:58 AM
stiksandstones
Aug 16, 2022 08:10 AM
CalvinC
May 21, 2022 12:18 AM
paipuky
Sep 20, 2008 04:30 PM
