Electrical F56 2015 Mini Cooper S - Replaced LED Headlights - Coding Data invalid
Old Oct 27, 2024 | 10:38 AM
TNMINICOOP's Avatar
TNMINICOOP
I have a 2015 F56 Mini Cooper S that I hit a deer in the damaged the hood and drivers side headlight. I purchased a 2017 F56 for the components that I was needing and I used both LED Headlights off the 2017 donor car to put in my 2015 Mini Cooper S that had what appears to be the exact same headlights.
I am now getting the following errors:
Front Light Left Coding Data Invalid
Front Light Right Coding Data Invalid
I found these errors using Bimmer Code and they are the only errors that I am seeing. that are RED in color
Can anyone point me in the correct direction to rectify this issue with the headlight coding it would be greatlt appreciated.
I feel that is all I will need to finish reassembling my Mini!
Old Oct 27, 2024 | 06:44 PM
maaii's Avatar
maaii
You can use esys to fix this issue. need to VO code your FLE on SVT tree.
It's very easy to fix.
Old Oct 28, 2024 | 07:48 AM
TNMINICOOP's Avatar
TNMINICOOP
i do have a back up that I made over a year ago. That may be a good reference point to start if I can get it to Lloyd’s.
i do appreciate that info and I will let you know how it goes!
TNHB2015CooperS
How To
Oct 27, 2024 08:44 AM
Stu-mon
Nov 8, 2021 04:12 AM
Pkupthpace
Feb 4, 2020 03:23 AM
soopah256
Jul 31, 2016 09:42 AM
honderpilot
Apr 14, 2015 08:31 AM
