R55 Cold Air intake Part question
Old Sep 16, 2024 | 06:07 AM
Statesman's Avatar
Statesman
https://imgur.com/a/DwFQeq2
looking to identify a part of the Cold Air intake. highlighted in red. Clubman R55 2011
yes I know the air filter is filthy
Old Sep 16, 2024 | 06:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Item #12 here:
https://www.realoem.com/bmw/enUS/sho...diagId=13_1200
Looks like AllMag has one in stock:
https://www.allmagautoparts.com/prod...re-box-r5x-r6x
Old Sep 16, 2024 | 06:38 AM
Statesman's Avatar
Statesman
Originally Posted by njaremka
awesome, feel dumb asking this but what does it do?
edit considering I have an after market filter/intake that isnt a closed system ... does it really do anything?
Old Sep 16, 2024 | 06:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That full duct helps direct cooler air into the intake system, so you definitely want it connected. That open intake box isn't doing you any favors.... The open box is just sucking in hot engine air.
Old Sep 16, 2024 | 07:07 AM
Statesman's Avatar
Statesman
unfortunately that's how I bought it 7 or so years ago. normally you can see where the manifold lines up with the box theres a metal ring that broke off that had a connection between the two that ive pulled out as im trying to sort out what to do to reweld that metal ring so i can reattach it and get at least lower temp air to that filter....
my thoughts are that the hot air isnt the worst thing, as the high performance filter is doing its job getting more air through (at least after I replace it with a clean one) and the engine runs well... Im not going to dump another 300+$ in parts to go back to a OEM setup so this is going to qualify under what's the best of the situation I have.
current plan is replace the filter, and Weld the metal ring back on so i can hose clamp the manifold back onto the filter box. anything I should think about here?
https://www.ddmworks.com/Mini-Cooper...rks_p_152.html is the filter setup
Old Sep 16, 2024 | 07:20 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Definitely missing some pieces....I would just pull that whole cold air duct right out, and through on a shelf. It's not doing anything at this point anyway. Keep it handy in case you ever decide to retrofit a different intake.
Crispybiscuit15
How to
Oct 5, 2016 10:14 PM
TaylorL99
16
Jan 11, 2007 05:06 PM
ubolt
Feb 3, 2003 10:21 PM
