R56 Loud "Tick" After Valve Job
Old Sep 14, 2024 | 03:21 PM
jnicho's Avatar
jnicho
Just changed out valve stem seals on my 2009 cooper. Also did chain/guide/tensioner while I was at it. Everything seemed to go fine and cat starts and runs fine, but I have a loud ticking noise now. I thought it was in the exhaust side valve train so I pulled the exhaust cam back out and checked/reseated rockers and lifters but no change. Video attachment for reference. Thoughts?
Old Sep 14, 2024 | 05:20 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Try to pinpoint noise source using an engine stethoscope.
Old Sep 14, 2024 | 05:28 PM
jnicho's Avatar
jnicho
I did that. Lead me to believe it was on the exhaust side but apparently not lol.
Old Sep 14, 2024 | 06:03 PM
Maybe, maybe not
Community Builder
Did you raise the front end on stands and use the stethoscope around the oil pan, timing chain area, serpentine belt, tensioner, alternator, friction pulley, and water pump?
Were any of the replaced timing chain guides broken? If so, did you recover all of the pieces?
Old Sep 15, 2024 | 12:01 PM
jnicho's Avatar
jnicho
Guides were all in tact. I pulled the valve cover again this morning. Found the problem! One of intermediate levers on Cylinder #1. I'm guessing the spring wasn't seated correctly on that one. Checking now to make sure I got all the pieces. Lots of tiny roller bearings. I'll fit a new intermediate lever and we'll try again.
Old Sep 15, 2024 | 12:55 PM
Maybe, maybe not
Community Builder
Glad you found it! Good luck with fix.
yyj3869
Oct 10, 2023 05:03 AM
gatorsr53
Apr 30, 2015 04:57 AM
toddcann
Mar 22, 2014 10:33 AM
El_Griton
Oct 15, 2006 03:23 PM
MiniMacster
Dec 13, 2005 06:46 AM
