R50/53 speedo pin outs needed
Old Aug 29, 2024 | 10:28 AM
daveking's Avatar
daveking
Hi
I have a couple of used speedo's and would like to illuminate
them as i want to hang the on the wall in my work shop.
What i need to know is what pins in the socket is the pos and neg.
Thank you.
dave king
Old Aug 29, 2024 | 10:54 AM
mrbean's Avatar
mrbean
If you're talking about the center-mount speedo, then unfortunately it's not that simple.
The GM module controls the headlights/taillights. When it turns them on, it sends a BUS signal to the center speedo which then illuminates the instruments. So the only way to get it to illuminate is to connect it to a CAN emulator and feed it the right information.
However, if you have a steering column mounted tach or speedo, then it's as simple as you' imagined. The center mount speedo just feeds those a 12V signal to illuminate.
Old Aug 29, 2024 | 11:19 AM
daveking's Avatar
daveking
Thank you for that.
Just as i thought
gchin
Jun 26, 2023 02:36 PM
Camaroboy14
Apr 8, 2015 08:05 PM
mpminiman
Classic Mini Talk
25
May 18, 2009 02:25 PM
not-so-rednwhitecooper
Electrical
16
May 14, 2009 03:29 PM
