R50/53 Accidentally dropped engine (passenger side).
Old Aug 27, 2024 | 08:30 PM
highdensity's Avatar
highdensity
Firstly, I acknowledge that I’m a moron and that today my ambition exceeded my talent.
I am in the middle of major service to include a pulley upgrade and have the car on jackstands, front service mode engaged/header removed/subframe removed and in my haste to remove the passenger side engine mount, i forgot to put support under the block and when i undid the four bolts, the whole thing slipped out and was dangling by the driver’s side mount. I had also just changed the cv axles so thankfully they didnt pop and goo out everywhere. I was able to jack up and reattach the mount to the chassis/block and am only suffering from psychological and emotional distress.
My question to yall now—do you think anything else could’ve come to harm through this? I bugged out on account of being molested by mosquitos, so i’ll check in the morning to confirm any damage. Many thanks in advace!
Old Aug 27, 2024 | 09:19 PM
noodlesandsam's Avatar
noodlesandsam
  1. Time for a new mount on drivers side. You could have torn it.
Old Aug 28, 2024 | 04:42 AM
BlwnAway's Avatar
BlwnAway
As long as it was "dangling" and the crank pulley didn't make hard contact with anything, you're probably ok.
I would however change the passenger/transmission mount as well, just as a precaution in case you damaged it by stressing the rubber portion.
Old Aug 28, 2024 | 05:32 AM
slofut's Avatar
slofut
I've been wrenching cars for 50 years and have gotten away with much worse, you did good. Lesson learned, prob nothing broke.
Old Aug 28, 2024 | 07:16 AM
Here2Go's Avatar
Here2Go
NAM Community Team
+1
Inspect the driver side transmission + gearbox mount(s). They are pretty beefy/substantial but I've read others have experienced having broken ones (that had not been a result of what you've encountered).
I can imagine if any potential damage/broken might have occurred around the mounting bolts.
As stated above; you're probably ok - but worth checking anyway.
Just my opinion having had a near similar experience.
Old Aug 28, 2024 | 07:49 AM
cooper48's Avatar
cooper48
The driver side is actually the strongest engine mount. I doubt that you caused any damage. A good visual inspection should help your confidence.
Old Aug 28, 2024 | 05:58 PM
highdensity
Thanks again all, no leaks, nothing obviously crushed. On the bright side, service isnt complete so i have plenty of time to rectify things as needed.
Demonican
Mar 24, 2024 08:18 PM
tosa mini
Jan 23, 2017 04:28 PM
Krisdadude
Aug 12, 2016 06:01 AM
RCC
May 30, 2013 12:30 PM
