R56 JCW R56 Motor Fan Stage 1 not working
Old Jul 15, 2024 | 02:26 PM
P@G's Avatar
P@G
Hi my Motor/coolant fan is only running sporadically on stage 2 otherwise it’s not running at all.
Is there a way to replace the resistor? Or do I have to replace the complete fan? Or is there anything else I should check first?
thanks
Old Jul 15, 2024 | 02:57 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
The ECU determines the fan speed.
Is a cooling fan fault code stored in the ECU?
Is the coolant level low in the reservoir?
Did you recently do any work on the cooling system?
Old Jul 15, 2024 | 11:38 PM
P@G's Avatar
P@G
there are no fault codes stored in the ecu and coolant level is full.
I’ve worked on the cooling system two years ago. It’s not that the fan is not working it’s only working on high speed. So it kicks on for apx 3 seconds goes off for 15 seconds before it repeats
Old Jul 16, 2024 | 08:27 AM
Maybe, maybe not
Community Builder
Try bleeding the cooling system.
Old Jul 16, 2024 | 07:04 PM
mkov608's Avatar
mkov608
It could be many things; there are two independent fan electrical circuits. Check both of your fan fuses first. Then check your first stage fan relay. Also, there is a resistor in the motor assy for the 1st stage fan. If that resistor fails, it could prevent the fan from working.
Old Jul 17, 2024 | 02:13 AM
P@G's Avatar
P@G
Thanks,
I've checked by manually turning on Fan Stage 1 and Stage 2 that stage 2 works perfectly fine. Stage 1 clicks in the relay but it does not turn on.
Fuses are both ok, I've switched the relays of the fans, same issue. So I guess it's the resistor. Where do I find that one? Is it in the Fan? I only see 2 wired going into the fan, is it pulling ground from somewhere else?
Old Jul 17, 2024 | 04:45 AM
mkov608's Avatar
mkov608
The first stage fan relay can click, but that doesn't mean it's sending out power to the fan.
Also, according to the schematic, you should have three wires going into the fan motor, stage 1 power, stage 2 power, and ground.
IM me your VIN; we need to make sure we're looking at the right schematic.
Old Feb 1, 2025 | 12:18 AM
JasonJasonJason's Avatar
JasonJasonJason
Slow speed fan. .issue
Hi.
There are lots on this but.......
2011 n14 manual JCW r56.
My slow speed fan doesn't not come in at all. With AC selected...without AC.
I can power up the fan directly at the plug......when 12 v is applied...slow and fast speed works.
I have a JCW . It has 2 relays and a 3 wire fan and a boost gauge and temp gauge. .
Temp gets to about 110deg c. And high speed comes in.
I checked my AC. There is no gas.
The temp gauge and sensor works and thermostat opens and coolant flows.
All fuses and relays work.
Suggestions.
My AC does not work. I assume the two are connected?
Fan slow does not work. Fault Code 2f3f
Old Feb 1, 2025 | 01:03 AM
mkov608's Avatar
mkov608
Which MINI are you working on? Justa, S?
Old Feb 1, 2025 | 01:07 AM
JasonJasonJason
It's in the correct thread. It's an R56. Not an r53 or an r72
Hi.
The thread is labeled R56 JCW. Fan stage 1 not working?
JCW are all s?
Old Feb 1, 2025 | 01:13 AM
mkov608's Avatar
mkov608
Yes I understand, but you never know who's going to chime in.
Old Feb 1, 2025 | 01:16 AM
JasonJasonJason
Right. Do you have something to say about the issue or is this one of those posts where someone has chimed in with nothing to offer?.
People who chime in with absolutely NFI will get a ****ton (metric?) of sarcasm.
Old Feb 1, 2025 | 01:17 AM
mkov608's Avatar
mkov608
Have you scanned the car? Any faults?
Old Feb 1, 2025 | 01:32 AM
JasonJasonJason
2f3f.
Old Feb 1, 2025 | 01:41 AM
mkov608's Avatar
mkov608
What year is your JCW?
Old Feb 1, 2025 | 01:47 AM
JasonJasonJason
2011 n14.
Manual.
Non run flats.
Leather seats.
Red trim.
Factory AC.
Old Feb 1, 2025 | 02:34 AM
mkov608's Avatar
mkov608
Janson, I can't find that 2F3F code in Alldata. Please scan the car under "global" OBDII, and let us know what P codes (if any) come up.
Old Feb 1, 2025 | 02:38 AM
JasonJasonJason
I have a generic scan tool.
Comes up as that. With note dme electric fan, activation power stage 2.
I have ista plus. Can connect to r53 but get no connection to r56 with k d can cable with switch in either position.
Automatically finds r53 vin and links to ecus in r53.
But not r56.
Old Feb 2, 2025 | 05:54 PM
JasonJasonJason
All codes have cleared for a few days now.
[Code has gone. Hasn't returned for a few days now.
Symptoms remain.
Thoughts?
QUOTE=JasonJasonJason;4690284]I have a generic scan tool.
But not r56.[/QUOTE]
Old Feb 3, 2025 | 07:31 AM
JasonJasonJason
I can bridge both fan relays and fan runs on slow and high speed. .
Old Feb 5, 2025 | 04:10 AM
Maybe, maybe not
Community Builder
But not r56.
Possible DME issue?
Old Feb 7, 2025 | 09:46 PM
JasonJasonJason
Possible DME issue?
​​​​​​Don't think so.
Old Feb 8, 2025 | 11:23 AM
habbyguy's Avatar
habbyguy
I'd look at the connections to and from the power distribution box in the schematics above. Of course, the first thing to check are the two associated fuses (40A and 50A). If they're good, then you need to find out if the low speed relay is being commanded on or not - should be able to do that with the plug disconnected and probing the relevant pin (8 or 11, whichever corresponds to the low speed circuit). If there's no signal (battery voltage) with the A/C on (or at least in a condition that should trigger the low speed relay / fan) then work back to the DME or whatever is behind the power distribution box. But if the signal IS there, it's down to the low speed relay being bad, or a bad connection between the low speed relay and the fan motor. Cable, plug or bent pin.
Old Feb 8, 2025 | 12:49 PM
Maybe, maybe not
Community Builder
Consider checking for battery voltage at OBD2 pin 16 and ground at pins 4 & 5 of the OBD2 connector. A problem at those pins would prevent your scan tool from connecting with the Mini ECUs.
kenquy71
22
Jan 3, 2023 06:28 PM
Angel Banda
Jan 31, 2022 08:15 PM
rdennisj
Feb 22, 2020 02:28 AM
Dave Elliott
May 8, 2016 06:04 PM
