2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Replacing spark plugs on F60
Old Jun 18, 2024 | 11:57 AM
miniRogue1's Avatar
miniRogue1
Hello all,
I have a 2019 F60 S and am thinking I may need to replace the spark plugs.
The car seems fine most of the time.
- Sometimes a bit hesitant when I accelerate, but I think that's just due to being an automatic and my mistiming the gear shift.
- Big thing is it's kind of chugs when A/C is on, but seems fairly okay when under acceleration.
Anyways, I just had the engine mounts replaced, so I don't think it's them, but I can bring back to dealer and ask. The other thing I've read to check is the plugs. What plugs do people buy as replacements and is replacing a fairly simple job?
Old Jun 19, 2024 | 01:42 PM
Saabbug's Avatar
Saabbug
Originally Posted by miniRogue1
Hello all,
My 2018 also exhibits the same issue. I do have 55k on it and am close to the recommended plug change. The job is not to bad but you will need a special spark plug socket which you can get on amazon for about 15 bucks. Also use the oem plugs which I believe are Beru. Do not cheap out on them. It will run you around 70 for a set from fcp euro.
Old Jun 19, 2024 | 01:44 PM
miniRogue1's Avatar
miniRogue1
@Saabbug awesome. Thank you
Old Jun 20, 2024 | 09:00 AM
Yep,
https://www.ecstuning.com/Mini-2019-...gine/Ignition/
Always check the plug type, some aftermarket pugs with have a 6 point socket of a different size. Most are that Beru 14mm design plugs
Old Jun 21, 2024 | 04:07 PM
cuppajoe's Avatar
cuppajoe
Anyone have the torque specs for the plugs?
Old Jun 23, 2024 | 06:34 AM
ghstrdr's Avatar
ghstrdr
23+ or - 3 nM....................as per NewTis F60 JCW All 4.
Old Nov 9, 2024 | 07:24 AM
CountryMiniS's Avatar
CountryMiniS
2018 F60 spark Plugs
Hello! I am also looking for DYI info on changing plugs for my 2018 F60. I have the tools. #1 plug has a vacuum hose over it… is it safe to remove? Also there is some kind of stability bar making it tricky. Any tips on doing this yourself?
Hello all,
Old Nov 9, 2024 | 09:17 AM
festus105's Avatar
festus105
I replaced my coils and plugs on my '19 F60 S. I did not remove the vacuum hose and was able to work around it... You do have to move the foam covering over the two coils on the right. I just moved it out the way. I also didn't remove the bar.
- Ken
Old Nov 9, 2024 | 09:24 AM
CountryMiniS
Great, thank you. I’m new to mini… Did you need a special socket for the coils? It looks like this nut is securing it.
-Brian
- Ken
Old Nov 9, 2024 | 01:53 PM
CountryMiniS
I figured it out- I haven’t had to use torx much before.
Old Nov 11, 2024 | 04:38 AM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
The coil packs are not very expensive. I usually replace the plugs and the coils together since I'm in there anyway.
miniRogue1
Aug 8, 2023 03:31 AM
AirborneMini003
Apr 18, 2023 12:28 PM
Ryan Hunte
May 5, 2022 01:32 PM
eric.stewart
Aug 9, 2020 09:06 AM
adam_randell
Nov 10, 2010 06:58 AM
