R56 Always reset variable camshaft timing adaptations after replacing timing chain?
Old Jun 5, 2024 | 05:21 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
2012 Mini Cooper N16
For example, if mechanical timing was perfect and no timing-related codes were thrown before and after a timing chain replacement, is resetting adaptations still required?
Old Jun 11, 2024 | 10:59 AM
white46's Avatar
white46
I was thinking the same, but since I had the tool for reset, I did it anyways.
VVTI, or Vanos, it controls advance/retard timing and made sense to me to reset the adaptation after hardware is replaced.
Old Jun 11, 2024 | 11:49 AM
Maybe, maybe not
Community Builder
Thanks for chiming in. I would have done the same as you if I had a tool that could reset adaptations.
While my N16 has 99K miles, the old chain was surprisingly tight; the tensioner felt like new; and the timing chain guides were completely intact. After installing the new timing chain kit, as well as a new auxiliary belt, water pump pulley, and PCV diaphragm the engine runs flawlessly as it did prior to the work and no fault codes have surfaced. My assumption is that, before and after timing chain replacement, the DME sees essentially the same engine mechanical timing and therefore does not require adaptation resetting. I'll post an update if issues eventually arise.
Minir602014
Feb 13, 2024 09:33 AM
Minir602014
Dec 5, 2023 06:35 PM
TuaLaoch
Jun 16, 2022 03:53 PM
Kirstin Pilkinton
Feb 27, 2020 10:13 PM
