timing chain off R60 mini (flywheel pin not locking)
Old Jun 4, 2024 | 07:12 PM
megrobelly1014's Avatar
megrobelly1014
I finished the timing chain and car did not start. I removed the valve cover to double check that but seems like only the two cams on top are in time but unable to get the flywheel in to lock it. Can I remove the cams on top while they are in the right time then manually rotate the crankshaft until pin gets in the put the cams back on top?. what would be the right procedure to do this?. do I need to remove the tensioner again?. please let me know.
Old Jun 6, 2024 | 06:21 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Rotate the crank to get the flywheel pin seated, then remove the cam bolts and rotate the cams into position and lock them down. Then, install two new cam gear bolts.
ducatiorourke
R55 :: Clubman Talk (2008+)
Dec 19, 2023 03:53 AM
Minir602014
Dec 5, 2023 06:35 PM
ptkacik
Nov 15, 2023 01:06 PM
Falken
Nov 3, 2022 05:47 PM
SchluckeWOT
R60/R61 Stock Problems/Issues
Jan 29, 2021 09:48 PM
