R55 Rough Idle/Bucking When Dipstick removed
Old Apr 21, 2024 | 02:33 PM
no cigar's Avatar
no cigar
Hi guys. First time poster here.
I am trying to float an issue I'm having here with daughters R55 Clubman where the engine begins to idle wildly/buck when the dipstick is removed.
I recently completed a repair on the car for a P0301 issue that developed suddenly during traffic. I replaced the cam cover, all spark plugs, and the coils. The car is now running smoothly and the P0301 cleared itself after a day or two. Today we went to change the oil, and after driving it around the block to check the level, the car started idling very rough and in a pulsing fashion. Prior to making the repairs I did note that there was a lot of vacuum sucking down on the oil fill cap. Do Mini's pull that much vacuum? Thanks for help.
Old Apr 22, 2024 | 05:22 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
For sure, you should be checking the oil level with the car off and on level ground. It is absolutely normal for the car to idle rough when the engine crankcase is open to atmosphere.
Old Apr 23, 2024 | 11:14 AM
Yep, don't remove the oil cap or dipstick when the car is running on a Gen 2 MINI.
Old Apr 27, 2024 | 05:46 PM
Toby B's Avatar
Toby B
...because it becomes a big air leak...
t
Eucoila
R57 :: Cabrio Talk (2009+)
Feb 24, 2022 07:17 PM
markc86
Sep 17, 2021 07:52 AM
Minidogger
Nov 15, 2019 05:00 PM
CooperS84
Apr 28, 2013 06:15 AM
automan21
Oct 4, 2011 12:17 PM
