Key Fob / Ignition Module Issues R-57S
Old Apr 20, 2024 | 08:13 PM
Dan_C_in_NJ's Avatar
Dan_C_in_NJ
Hello All, I purchased a 2012 R-57 S (Automatic) a while back and it has an ongoing problem that I am not sure how to fix. The car is not releasing the keyfob. Sometimes it will act normally (I previously owned an R-55 S) but mostly it will not release forcing me to yank the fob out. I thought the problem was a bad ignition/starter module, so I ordered one and just installed it. No change.
I also have an issue with the interlock for the Auto Trans. The previous owner, a Mr. Gorilla, apparently liked to shift out of Park without the car being running. At present I have not dropped the shifter box to see what I can do but that is probably next.
So here is my question, could the broken shifter interlock be the cause of my Keyfob issues?
A side issue, that I do not think is related, is the paddle shifters do not function or at least I am not using them correctly (first mini with auto and paddle shifters). I have not been able to find a description for usage: One at a time, both together. Manual shifting is possible via the floor lever in Manual, just no paddles.
Hope the collective can assist.
Thanks in advance,
Dan C in NJ
Old May 1, 2024 | 07:23 AM
Dan_C_in_NJ
Mini Keyfob Release Fixed
To All. I have a resolution to my ignition issue. Te key fob needed to see the secondary interlock of the automatic trans in PARK to release the key.
The pictures show the plastic interlock before and after. I found a YouTube video detailing this problem and how to manage the fix.
Before in pieces After Reassembly
ki4npz
Apr 26, 2024 05:31 PM
Ryan-N57
Oct 25, 2022 05:14 PM
Tombstone
May 31, 2022 08:55 AM
ManiX
Apr 24, 2020 01:25 PM
Bryan Collett
Jan 12, 2012 08:33 AM
