Mini cooper50 windshield wiper turned on & won't stop
Old Apr 19, 2024 | 10:22 AM
EdwinG.'s Avatar
EdwinG.
I tried using the rear cigarette light, since I already had my trunk open I decided to use it, to inflate my tire. The moment I turned it on you can tell something went wrong. Both my front & rear windshield wiper turned on after that & won't turned off, I checked all the fuses & non are blown, I took of the fuse for the front to make it stop for now but can't locate the one for the rear, also trying to see how to fix the problem
Old Apr 19, 2024 | 12:28 PM
mrbean's Avatar
mrbean
The wiper motors are controlled by the "general module." It sounds like your inflator may have caused a voltage dip that made the module go haywire.
I would scan the module for errors to see what it thinks. At a bare minimum, you can try disconnecting the battery for 20 min or so to see if it resets.
BTW, fuse #17 in the driver's footwell should feed the rear motor.
bbarlow641
Jul 30, 2020 10:14 AM
Monk Edsel
Jan 18, 2009 06:34 AM
ACEkraut11
Feb 7, 2008 08:04 AM
jspears05
Apr 24, 2007 06:20 AM
LockjawDavis
29
Mar 6, 2003 04:28 PM
