R50/53 Smoke testing intake
Old Apr 18, 2024 | 05:48 AM
ewgoforth's Avatar
ewgoforth
Hi,
I tried smoke testing my intake with a homemade smoke machine looking for leaks, but I don't think the smoke was going past the throttle valve. How do I hold it open while the engine is off, or get smoke into the intake?
Old Apr 19, 2024 | 09:17 AM
mrbean's Avatar
mrbean
I've never had to do this on a Mini, but here's some ideas:
1: Ignition on but engine not started - does the throttle open when you push the gas pedal?
2: Rotate the engine by hand until one of the cylinders is about 90° past TDC and the intake valves are open. Remove the spark plug and pump smoke in.
Old Apr 20, 2024 | 05:32 PM
ghostwrench's Avatar
ghostwrench
If I were going to smoke test an R53, I would probably go in where the TMAP on the intake manifold is. You will have to block the throttle body because smoke WILL go around the throttle blade and come out of the air filter.
Texasbaehr
Oct 3, 2022 06:56 PM
bdr127
Oct 19, 2010 03:47 PM
Phantom
Feb 10, 2007 11:27 PM
Flatsix
St. Louis MINI Club
Dec 10, 2003 12:57 PM
