R60 R60 Crank But No Start Lots of Codes
Old Mar 24, 2024 | 03:23 PM
cchitko's Avatar
cchitko
Hi All,
Looking for some advice. Have a 2014 R60 Countryman All4. Had a blow head gasket which I fixed and got car running, Unfortunately the freeze plug on top of the head had popped off during the initial run (probably due to SLIGHT warpage in head) causing coolant to leak into oil. Tapped a new 18mm plug into that freeze plug hole so it wouldn't pop out again. Compression still good on all 4 cylinders..
However, now I have a different problem. Probably electrical in nature since at some point the ground wire to the engine (you know, that tiny ground wire that connects to the cylinder head) broke off. I'm thinking it shorted something out. Again, the car ran fine until the plug/coolant issue but I was luck to catch that early on so the coolant going into oil it didn't do any other physical damage to the engine.
Here are the symptoms:
  • Crank but no start, no spark
  • Tach not moving when cranking (telling me crank position sensor not sending signal)
  • Compression is good on all 4
  • Have a bunch of codes which are probably red herrings. I swapped out another Valvetronic motor and new accelerator pedal and didn't fix issue. See attached screenshot of scan tool error codes that always come back after clearing.
I'm not too good at diagnosing electrical issues. Anyone have any suggestions on where to start? Again, it's probably something with a bad ground, or shorted out wire but not sure where to look?
Thanks in advance for any help!
Old Mar 25, 2024 | 05:43 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
The DME is possibly damaged.
Ox36E2: DME, internal fault, monitoring 5V sensor supply: Voltage outside valid range
trackntrail65
Sep 19, 2023 06:44 AM
cooper48
Feb 14, 2021 07:54 PM
Vexxed
Mar 15, 2020 03:35 PM
thewizz
Nov 2, 2016 09:10 AM
Dev1ld0g
Apr 7, 2014 03:26 PM
