R50/53 '03 R50 question
Old Mar 23, 2024 | 03:33 PM
Titcobra's Avatar
Titcobra
'03 R50 question
So I already have the 6 speed getrag swap in my whip ....if I'm researching the possibility of doing a r53 into the r50 swap basically an S motor into my R50 base model....does that being completed already make swapping the motor in any easier? Like beyond the obvious . This being my first mini I have read a lot of posts about the swap and if I'm remembering correctly alot of the discussion is centered around getting the 6speed in there and bunch a lil parts n chit..
Would I be lucky enough to just be matter of straight fwd pull out, put back in sorta job? Make any sense y'all?
​​ Hopefully y'all understand, sometimes I have problems putting thoughts into words
Old Mar 23, 2024 | 04:27 PM
deepgrey's Avatar
deepgrey
I suppose that depends on your definition of straightforward. You get the joy of changing basically everything under the hood… and the hood itself. You’ll have to relocate the battery, and I think you also have to chop off the main engine bay harness connector, too.
I seem to remember people swapping the DME, EWS, and a few other things, but there may be another way around that with someone who can reprogram DMEs.
Old Mar 25, 2024 | 10:42 AM
doperobot's Avatar
doperobot
Right on, yeah I planned to move the battery back and relocate ps steering res.
I still got a ton of research before I decide. Thanks for the quick reply👍
Mini860
Cooper (non S)
16
Aug 8, 2020 12:50 PM
ItzNeil
Sep 2, 2017 11:35 AM
Chibi Archillies
11
Jul 15, 2012 01:44 PM
BembellandJester
Cooper (non S)
35
Dec 21, 2008 07:43 PM
Hawkins115
Mar 16, 2008 05:11 AM
