2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Armrest retrofit
Old Mar 7, 2024 | 12:41 PM
robby71's Avatar
robby71
Armrest retrofit
Hi
Just bought a used F60 Cooper S and want to upgrade it a bit.
I'm looking to install the factory centre armrest but cannot figure out if i need the centre console as well or do i remove the rear oddment tray and the armrest will slot through that?
Do i also need a bracket that bolts to the floor which the armrest fixes to like on the f56 or does it fix to the plastic console?
Old Mar 8, 2024 | 01:54 PM
Here you go, you can see it broken down here and on the part. Does that help/
https://www.realoem.com/bmw/enUS/sho...diagId=51_5621
https://www.realoem.com/bmw/enUS/sho...diagId=51_5626
https://www.ecstuning.com/b-genuine-...t/51169332831/
Old Mar 10, 2024 | 09:14 AM
robby71's Avatar
robby71
Thanks ECS - the problem i'm having is finding out where the armrest brackets fit to. It has 4 holes so must attach to a bracket that is attached to the floor but the realoem diagram doesn't show such a mounting bracket?
The F56 does have a bracket for the armrest console and it's obvious in the realoem diagram but even breakers yards who are selling the armrests can't say if there's a bracket which is weird if they've unbolted the armrest?
RedMiniBirmingham
Feb 12, 2011 02:30 PM
mollycart
Jan 6, 2008 08:21 AM
DoubleNick
Sep 23, 2004 08:31 PM
zfxr
Aug 6, 2004 12:04 AM
Mighty_Boognish
Jul 22, 2004 10:54 AM
