R58 Coupe S to JCW Caliper Conversion Q’s.
Old Feb 27, 2024 | 07:11 PM
Iris's mini's Avatar
Iris's mini
Hello Mini family!
Q? I have a 2014 Min Cooper S Coupe R58. I would like to convert my cooper s standard calipers to a JCW Brembo set or a BBK. Is it a direct swap/ fitment from JCW Brembo’s to Cooper S?
IF SO…
-What parts are needed to make it work and complete the conversion? JCW Brembo calipers, Brake lines, JCW size rotors, JCW Brembo Brake pads?
-Any other parts are needed to complete the install?
IF NOT…
-Any recommendations for a Big Brake kit?
I found a JCW Brembo style caliper on eBay from the UK Called Kinetix / Budweg high performance brakes. And im thinking of purchasing their set as it’s a replica design of the JCW Brembo caliper. It would be easy to simply purchase their caliper, brake rotor, pads and brake lines to have a new complete set for the front. Would this be a good thing to do or am I better off buying the official JCW set?
Your help and recommendations would be greatly appreciated and thanks in advance.
Old Feb 27, 2024 | 08:44 PM
chrunck's Avatar
chrunck
From what I remember reading on here somewhere, Budweg remanufactures JCW calipers and resells them. So they should be identical to the real deal.
Old Feb 28, 2024 | 04:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What he said about Budweg…
You will need the calipers, pads of choice, brake lines, and the JCW 316mm rotors. Direct swap. Make sure you’re running 17” rims, too.
Old Feb 28, 2024 | 05:10 AM
DogfaceSGM's Avatar
DogfaceSGM
That is what I thought. JCW brakes do not fit inside the 16" rims.
Old Feb 28, 2024 | 08:06 AM
Yep info here: https://www.northamericanmotoring.co...alipers-2.html
mini2super
Oct 11, 2021 07:37 AM
PhoR53
Jan 3, 2017 02:28 PM
Noir2005
Dec 10, 2012 11:35 PM
RedBaronF2001
Tires, Wheels, & Brakes
Mar 8, 2005 05:29 PM
