R52 Not sure where to start - top issues
Old Feb 27, 2024 | 03:12 PM
luxmatic's Avatar
luxmatic
Hello, new to the forums! I have an issue with my 06 R52S where the top will only go to sunroof open, then no more. No flashing lights or any attempt to go further. Searched google for this code to no avail, hoping someone has an explanation here!
28. CVM. Switch, arrester hook locked: short circuit to ground or open circuit.
Thanks!
Old Feb 28, 2024 | 12:32 PM
zabond's Avatar
zabond
make sure the rear parcel tray is making contact with the micro switch on the l/h side and the rear hood locking levers are fully locked, the micro switch can be a tricky one to see as the tray may be down but not operating the switch, this was a problem I had and had to put a piece of rubber tube on the end of the tray leg/part that makes contact with the switch as the tray had warped a bit and not making contact on some occasions
Russ
Old Feb 28, 2024 | 07:30 PM
Fly'n Brick's Avatar
Fly'n Brick
Russ
There's also a push button switch in the upper left side of the boot hatch frame. It's a short throw switch. I stuck a small chair leg pad on the boot hatch opposite with never an issue...so far.
Scoobaru2010
Jun 12, 2023 08:56 PM
Black Forest
Nov 25, 2019 08:29 PM
SupeDuper
Jul 29, 2014 03:05 PM
dkamp
R55 :: Clubman Talk (2008+)
Jul 18, 2008 02:43 PM
