R50/53 How much does a stock slave cylinder move???
Old Feb 20, 2024 | 01:29 PM
Boostmaster's Avatar
Boostmaster
Need to get some input from you all. Having issues with getting the car into gear when it is running. When it is off there are not issues. When it is running the odd gears will not engage. Thought it might be the slave cylinder. As it rests from flat plastic (the base of the slave) to flat metal (the clutch fork engagement rod) it is about 50mm. When the pedal is depressed it moves to about 60mm so a whopping 10mm difference. So there is engagement but I am thinking that there is not full engagement. Of course pedal springs back but it is not very firm.
Seems too short of travel. Suspect the slave may be faulty. No leaks and bled several times.
Can someone give me an idea of what their "throw" is on their slave cylinders? Or any other ideas???
Old Feb 20, 2024 | 05:04 PM
Boostmaster
Just found this: Not sure yet on my issue
Old Feb 26, 2024 | 05:07 PM
Boostmaster
Moving this to my larger thread to see if I get any input.
https://www.northamericanmotoring.co...ome-ideas.html
Mrmotard
Feb 8, 2019 04:19 PM
solomio
Oct 19, 2018 11:12 AM
Mojo Jojo
Nov 1, 2013 06:49 PM
AliceCooperWA
Mar 28, 2011 01:37 PM
