R56 Question for UltraGauge owners (R56 N18)
Old Feb 19, 2024 | 12:17 PM
MINIGTS's Avatar
MINIGTS
Hi friends,
I purchased from the company UltraGauge model EM Plus v1.4d (last version).
Although it is written in the user manual that there is an "oil temperature" value - The value of oil temperature does not appear in the values ​​of my UltraGauge. I have R56 N18. Is there anyone with an UltraGauge that can see oil temperature?
Thanks in advance
Old Feb 29, 2024 | 04:11 PM
Josh Falk's Avatar
Josh Falk
Originally Posted by MINIGTS
Hi friends,
Thanks in advance
2013 R56 N18 and UltraGauge owner. There is no oil temperature reading as there is no oil temp sensor on the car. Any OBD reader that offers you an oil temp reading is an approximation based on other readings. If you want oil temp, you have to mod it In yourself.
Old Feb 29, 2024 | 10:07 PM
MINIGTS's Avatar
MINIGTS
Thanks. interesting. Because ScanGauge (a competing company) writes on the website that the ScanGauge scanner shows oil temperature at N18. So it's not really oil temperature?
https://www.scangauge.com/support/x-...mini-specific/
Old Mar 1, 2024 | 02:54 AM
Josh Falk's Avatar
Josh Falk
If they advertise an oil temperature reading, it is not from an actual oil temp sensor, it is a number calculated from other readings from things like coolant and intake temp. I'm not even saying it isn't accurate- what I am saying is that it's based on a formula from other actual temperature readings because there is no sensor that reads the actual temperature of the oil.
Old Mar 1, 2024 | 06:38 AM
DogfaceSGM's Avatar
DogfaceSGM
To be honest, I don't worry about oil temp so much as Oil pressure and Coolant temp.
Old Mar 1, 2024 | 10:53 AM
MINIGTS's Avatar
MINIGTS
The UltraGauge scanner doesn't show "oil pressure" either... do we have an oil pressure sensor in the R56 N18?
Old Mar 1, 2024 | 10:54 AM
MINIGTS's Avatar
MINIGTS
Thx Josh
Lou@Prototype-R
Mar 6, 2026 01:16 AM
mkov608
Jul 21, 2022 04:02 PM
Grey Thunder
R59 :: Roadster Talk (2012+)
Jul 20, 2022 01:25 PM
Danielng0811
Apr 25, 2014 07:58 PM
