R50/53 Engine pull for clutch & other jobs
Old Jan 23, 2024 | 07:14 AM
shadetreemech's Avatar
shadetreemech
Last year I did subframe off, restoration and repaint last year along with all the bushings, tie rods, ball joints, suspension, power steering system, supercharger service, pulley, tensioner.
Now! Wonderfully, my clutch is slipping!
Apparently a lot of guys use this as a subframe off restoration job.
Since I've already done this... whatcha all think of pulling the engine instead?
Also!
I'd like to tackle any other jobs that may bite me again.
Need to be able to take this car on some long road trips without feeling like I'm gambling...
Any ideas for other jobs for reliability or opportunity upgrades?
So far I've got:
- rear main seal
- guide tube and seal
- LSD
Thanks!
Old Jan 28, 2024 | 07:24 PM
Onizukachan's Avatar
Onizukachan
I did two engine outs with subframe left. It’s actually pretty easy.
things to watch out for, the heater hoses with all the t fittings, separate a heater core hose off them. Untwist the engine connector located on drivers side engine bay, pop the lower ball joints off the lower arm so you can swing them out to remove the axles, amd the 3 engine /trans mounts.
The clutch slave can be unbolted from trans and with line wiggled out and up out of the way so you don’t even have to crack the line.
oh and the starter wire and there is one vacuum line to brake booster with a quick disconnect. As well as unplugging a line of the evap solenoid iirc.
all in all it’s actually a pretty manageable job. The thing comes out as a full assembly with full vacuum lines and wire harness attached so you can separate on the ground and
Old Jan 29, 2024 | 07:50 AM
cooper48's Avatar
cooper48
What ^^^ he said. Much easier to replace the clutch components and realign/reinstall the transmission with the engine out.
Old Feb 2, 2024 | 06:47 AM
Boostmaster's Avatar
Boostmaster
^^ Be careful what you wish for. I pulled the engine for something minor and it turned into an odyssey.
Here's my thread if you want to live my pain before you start yours.
https://www.northamericanmotoring.co...ome-ideas.html
Old Feb 7, 2024 | 09:43 PM
AshlyGrant's Avatar
AshlyGrant
Hehe, I can feel your pain, Can I ask a thing?
Spoiler
Old Feb 9, 2024 | 04:27 PM
Boostmaster
Ask away- not sure who you're addressing but I am happy to answer any questions if I have insight.
KingArthur16
Sep 27, 2022 11:15 AM
Racingguy04
Mar 4, 2020 07:27 PM
KingArthur16
Jan 13, 2020 08:56 AM
Rrotz
Jun 26, 2015 07:33 AM
countryboyshane
Aug 14, 2013 09:18 AM
