F60 How to clean the throttle body of the F60
Here is the throttle body and location. So just clean it with throttle body cleaner and I use a small clean cloth if you unbolt the whole thing it might be easier to get to the back.
Make sure you are not hard on pushing back the butterfly valve as you dont want to damage those internal gears as its electronic. That charge pipe might have to come out to access it and not get it on that sensor. # 2 https://www.ecstuning.com/b-genuine-...e/11617619272/
#7 has to come off also https://www.realoem.com/bmw/enUS/sho...diagId=13_1570 https://www.ecstuning.com/Search/Sit...h/11618511338/
When you putt it back together make sure its sealed up and the orings dont leak.
https://www.realoem.com/bmw/enUS/sho...diagId=13_1567
https://www.ecstuning.com/b-genuine-...547619008~oem/
https://www.ecstuning.com/b-vdo-part...547619008~vdo/
Mister Spice
131
Jan 18, 2023 09:13 AM
