Cold start problem, code p111b
Old Jan 8, 2024 | 06:39 AM
Matt4269's Avatar
Matt4269
Hi all,
Over the past few weeks my 2007 justa has had a lot of problems starting cold. The idle is fine for a few seconds, and then splutters/stumbles over itself for a few seconds until it eventually sorts itself out, coming very close to stalling but not quite. It's had an intermittent p111b code that occasionally goes away. I've recently had a full engine rebuild, with new rings, vanos solenoids, timing chain kit, valve cover etc so not sure what could be causing this. I have noticed a small coolant leak near the water pump and the thermostat appears to be stuck open (while looking at the temps after a first start it takes a long time to warm up, and doesn't reach 105° and drop back down to ~50 like it used to) I have these parts on the way, but could that cause the rough idle/running rich engine codes? It ran the same before the thermostat started playing up so I'm really not sure.
​ant help would be very appreciated, and I can attach a video of it starting if that would help.
Subscope
Sep 15, 2023 01:22 PM
tony2fingers
Jun 8, 2019 06:28 AM
ccain
Jan 7, 2013 05:45 AM
particle
Apr 13, 2012 02:54 PM
vereinmann
Dec 21, 2010 04:09 PM
