R56 Drain engine oil for timing chain replacemment?
Old Jan 5, 2024 | 09:14 AM
white46's Avatar
white46
Hello,
As title says, do I need to drain engine oil for replacing timing chain/guide? This is for N18 motor.
I just did the engine oil change last week and planning to do timing chain/guide next week hence the question.
Thanks!
Old Jan 5, 2024 | 09:49 AM
DogfaceSGM's Avatar
DogfaceSGM
First, I think I would have done the timing chain 1st.
Second, are you doing the timing chain/tensioners as a preventative or do you have a cause?
Old Jan 5, 2024 | 10:00 AM
white46's Avatar
white46
I'll be doing the chain/guide as "while I'm in there", because I'll be doing the valve stem seal.
Old Jan 5, 2024 | 11:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I'm 98% sure that the timing chain service is all done above the oil level in the oil pan. You could probably do it without draining the oil.
Old Jan 5, 2024 | 12:27 PM
mkov608's Avatar
mkov608
To change the timing chain, you have to remove the front crankshaft hub bolt (the bolt must be replaced). One the hub is removed, you've disturbed the seal between the hub and the seal, so you'll want to replace the seal. If you don't drain the engine oil, there is a chance some oil will leak out of the block when you remove the hub seal.
Remember the new hub seal must be installed dry (do not oil it), once installed, it must sit (no engine rotation) for 4 hours to normalize. Failure to do this will result in an oil leak. Install the hub first, and then press the seal into place.
Old Jan 5, 2024 | 01:57 PM
white46's Avatar
white46
Yes. That's was my worry too. There might be enough oil to leak out from the hub bolt hole as the hub bolt and seal is removed.
For anyone who replace timing chain/guide, did you guys drain engine oil?
Old Jan 8, 2024 | 02:13 PM
mkov608's Avatar
mkov608
No, it's not in the TIS list of preliminary tasks for timing chain replacement.
Old Jan 10, 2024 | 10:54 AM
white46's Avatar
white46
Oh nice. Thanks!!
Old Jan 27, 2024 | 01:56 PM
ptkacik's Avatar
ptkacik
FWIW, I just replaced my timing chain after an oil change and didn’t change the oil afterwards. No oil leaked out during the seal replacement.
Peter
Old Jan 27, 2024 | 02:24 PM
white46's Avatar
white46
Peter
Great. Thanks!!
Wondering.. how many hours did it take?
Old Jan 27, 2024 | 02:31 PM
ptkacik's Avatar
ptkacik
Ha! Too many but I’m retired and its my third car so I didn’t care. Probably three days but an experienced shop guy could probably do it in a few hours, (maybe I could repeat it on a Saturday).
I also replaced my valve guide seals so I bought a ton of specialty tools for the valve timing, crank holding, seal installation, and valvotronic springs.
Peter
Old Jan 31, 2024 | 12:23 PM
white46's Avatar
white46
Peter
Good to know. Thanks! I'm going to take time with it too. Not rushing. 3-4 days I guess.
ptkacik
Oct 8, 2023 07:26 AM
healtoe86
Sep 15, 2020 07:25 PM
SPRINTCARS
R60/61 Cooper S Drivetrain
Oct 8, 2013 09:57 PM
coolewong
67
Jan 21, 2013 07:06 PM
TimG517
Nov 27, 2012 09:05 PM
