R59 leaking connection
Old Dec 26, 2023 | 07:20 AM
joepf01's Avatar
joepf01
leaking connection
I own a 2012 Mini R59 Roadster. I have a fuel leak at a connection just below the firewall. Looks like a rodent may have started this. Does anyone know of a good source for fuel line components for my Mini?
Old Dec 26, 2023 | 09:44 AM
https://www.realoem.com/bmw/enUS/sho...diagId=16_0679
Looks like number 2 line? Feed line.
https://www.ecstuning.com/Search/Sit...h/16122752332/
The line up top looks like the feed flex line to the HPFP? Cooper S? Up to 03/2012 production.
https://www.ecstuning.com/Search/Sit...h/13537605189/
Old Dec 26, 2023 | 11:05 AM
joepf01's Avatar
joepf01
Fuel line leak at connection
It is indeed the #2 feed line. That line attaches to the feed line going to the fuel pump. Is the connector on that #2 line replaceable or must I purchase and install the entire line?
Thanks for your responses.
Joe ferrari
Old Dec 26, 2023 | 01:03 PM
Thanks!
Plastic line damaged, you will just need that plastic line and you have to disconnect that fuel line which has a special end. If the flex line and fuel line 13537605189 both have damage, replace them both.
Old Dec 26, 2023 | 02:30 PM
joepf01's Avatar
joepf01
Thank you for your input.
Joe
Old Dec 27, 2023 | 06:37 AM
Welcome.
Old Jan 5, 2024 | 09:00 AM
joepf01's Avatar
joepf01
Upon closer examination, the plastic insert that should be inside the connector that attaches to the fuel feed line appears to be dislodged. I cannot push it back in properly. Do I need a tool for the proper placement on this insert? The black insert is clearly visible on the right end (incoming) of the hose pictured below.
TY, Joe
Old Jan 5, 2024 | 01:59 PM
Its that one that holds it in. So you can insert it.
https://www.ecstuning.com/b-schwaben.../015345sch01a/
Old Jan 5, 2024 | 04:57 PM
joepf01's Avatar
joepf01
So I understand this, the line is disconnected. The clip is inserted on the disconnected male end. The two ends are coupled. The tool is then removed. Correct?
Old Jan 8, 2024 | 08:20 AM
Yep, its a holder for the line to push in then the black part snaps back in place.
Old Jan 8, 2024 | 09:33 AM
joepf01's Avatar
joepf01
I've ordered the tool from. I'll give it a try.
TY
Joe
Old Jan 8, 2024 | 09:34 AM
Ok, thanks and let me know how it goes.
997MR
Mar 14, 2023 01:32 PM
ndale
Jan 30, 2019 12:49 PM
hotairgypsy
Aug 20, 2018 05:30 PM
midacl
Nov 10, 2016 10:14 AM
Madoc
Classic Mini Talk
15
Nov 1, 2007 05:29 AM
