R50/53 R53 Spark plug blew out
Old Dec 4, 2023 | 11:25 AM
kimimini's Avatar
kimimini
My 06 S decided to blow out the spark plug on cylinder 1. I was able to slightly tighten it and drove 60 miles home. From my researches time-sert is the best solution over helicoil.
1- Is this the right kit? M14x1.25? 7mm insert?
2- I’m thinking about doing all 4 cylinder at once so I won’t have to deal with this anymore. Good idea?
3- Which 1 step colder spark plug do you recommend as I plan on replacing all four.
4- Any recommendations for spark plug boot? Currently using MSD ignition.
Thanks!
Old Dec 4, 2023 | 01:23 PM
megaDan's Avatar
megaDan
Thanks!
1. 7mm seems awfully short. The length of the plug is ~19mm IIRC. That kit will work, but it seems awfully pricey. I had good luck with the kit NAPA sells. It was an emergency and I was 800 miles from home, but their tap was sharp and the inserts were steel. Kits from other stores used aluminum inserts which kind of defeats the point IMO.
2. I think this is overkill, and gives you 4 more chances to screw something up. I too had the same thought when I did mine. But if anything, this experience will encourage you to check your plug torque more often. Ever since this happened once ~5 years ago, I've never had a plug come even remotely loose.
3. NGKBKR7EIX. NGK 2667. My go to plug for boosted applications.
4. Never had an issue with OEM. Lots of people hate on MSD, not sure why. But I don't see why its needed either.
Old Dec 4, 2023 | 03:34 PM
kimimini's Avatar
kimimini
Thanks, much appreciated! It is pricey indeed. Do you happen to have a link or description of the Napa kit that worked for you? I need to figure out the insert length as 7mm was the one recommended on time-sert webpage.
Old Dec 4, 2023 | 03:39 PM
kimimini's Avatar
kimimini
@megaDan Is this the one you used?
Old Dec 4, 2023 | 05:05 PM
The Devil Z's Avatar
The Devil Z
Because they have been known to blow the stock dme/ecu ignition mosfet/driver dwell time etc
Old Dec 4, 2023 | 06:58 PM
Turbo R53's Avatar
Turbo R53
Were you running stock plugs?
I use BKR7EQUP aka JCW plugs, they are one step colder than the stock R53 plugs. I never had an issue with blowing them out of the head because it's basically a stock plug.
Old Dec 4, 2023 | 08:20 PM
kimimini's Avatar
kimimini
Didn’t check the model on what I currently have when it was out but I’m sure it was NGK. Will check later.
Stu-mon
Mar 1, 2023 08:41 AM
maniacalmorgan
Jan 1, 2020 11:20 AM
Haiden1991
May 28, 2015 06:03 PM
DrkSilver163
Electrical
Apr 4, 2005 07:49 PM
