R52 Brake Lights Always Stay on... Running Down Battery!
Old Nov 11, 2023 | 01:22 PM
BigDog9721's Avatar
BigDog9721
All, so here's what's happening... let's start with me disconnecting the battery (no brake lights on), then I reconnect battery, start car, press brakes, all work fine (on and off). Then i turn off car and rear brakes lights come on and stay on... I am befuddled! Any thoughts would be GREATLY appreciated! By the way, I replaced the brake light switch already!
Old Nov 14, 2023 | 08:54 AM
msjulie33's Avatar
msjulie33
Bad ground somewhere or bad starter switch?
Old Nov 20, 2023 | 01:33 PM
BigDog9721's Avatar
BigDog9721
engine starts fine... ground?
Old Nov 21, 2023 | 08:07 AM
RockC's Avatar
RockC
Any chance the brake lights being on is some kind of MINI/BMW way of signaling a problem with brakes? Or more specifically the brake hydraulic system?
See if by manipulating the brake pedal linkage/brake light switch you can cause the brake lights to go off. This would go a long way to eliminating the brake linkage keeping the switch closed or the switch being closed on its own.
If the car fitted with a traditional ignition switch that requires a key to be turned to start the engine or turn on the accessory power a bad ignition switch can be the culprit. There is typically an enclosed number of electrical contacts which are operated as the key is turned. These can wear out.
Doing this multiple times wiggling/pushing/pulling on the key while turning it and observing if there are any "weird" electrical behavior like dash lights not coming on fully or only coming on in part, and in this context if the brake lights are affected, could find the ignition switch is bad.
Old Dec 16, 2023 | 04:47 PM
scf's Avatar
scf
X15 42 pin connector below the interior fuse block. Check for corrosion and/or broken wires.
It'll be why your OBD isn't working too.
Old Dec 16, 2023 | 08:25 PM
BigDog9721's Avatar
BigDog9721
X15 Connector.... at first I didn't know what that was... so i researched it... the fuse box was where I was heading next… thank you scf... I'll keep you posted!
MiniManAdam
Feb 19, 2021 04:58 PM
gpop
Jul 22, 2019 05:28 PM
bavmotors
Dec 10, 2015 03:01 PM
CeliaMarie
Mar 22, 2009 02:35 PM
Aeromax
Off-Topic :: Autos
Mar 12, 2007 04:26 PM
