2007 Throttle Body Issue
Old Oct 30, 2023 | 02:10 PM
harshdoug's Avatar
harshdoug
I have used this site so much as a non member while workingontis car, tons of great advise. However my searches lately hasn't produced the answer I was looking for.
I am working on my 2007 Cooper S R56 Turbo with about 137k miles. I needed to replace the leaking cross over coolant pipe, so to give myself more room I took off the intake manifold with the throttle body (original TB to car) attached. Since I had it all apart I figured I would clean out the TB, however when doing so I manually moved the gate inside the TB to throughly clean it. At the time I did not realize this was a no no. Once I got it all back together and fired it up it was running like crap almost stalled and threw me a bunch of TB codes (2B32, 2B31, 2B1E, 2B2B, 2B22) and went into limp mode. I have tried all of the non scanner options to re code it but have not had any success.
My question is should I just replace the TB since it is original? If so will I still need to re code the new one to the car?
Also does anyone know of a scanner tool that will re code at TB to Minis that costs less than $500?
Good news it that it doesn't leak coolant any more, I installed the ECS aluminum pipe, as Mini should have originally.
Old Nov 9, 2023 | 11:10 AM
Thanks for the order!
Yep you might need to recalibate the TB. I hope you did not damage or jump a tooth on the gear. If you did that it needs replaced.
Try this first.
https://www.precisionecu.com/blogs/e...i-step-by-step
Or
To reset the MINI Coopers throttle body please make sure the ignition is Turned Off. Press the Gas Pedal to Full Throttle while the ignition is off. Turn on the Ignition to the 3rd position for 30 seconds. Do Not Crank the Vehicle. Do Not let go of the Throttle.After 30 seconds are over, Turn Ignition Off and Remove Key. Do Not let go of the Throttle. After Key is Removed, let go of the Throttle and wait 30 seconds. After 30 Seconds, the Car can now be Started normally. You have now completed the throttle body adaption reset.
https://www.northamericanmotoring.co...daptation.html
If still not working then here is the throttle body. 13548675278 or 13547604918
https://www.ecstuning.com/Search/Sit...h/13547604918/
Old Nov 10, 2023 | 03:27 AM
Yoshimura 1's Avatar
Yoshimura 1
Try this first.
Or
Okkkkkay.....that's good on the reset sems easy enough to do.....
Old Nov 10, 2023 | 06:34 AM
Welcome.
Old Nov 13, 2023 | 04:52 AM
harshdoug's Avatar
harshdoug
Thanks for the suggestions, but neither one of those worked. Ended up replacing the throttle body. That solved the problem and cleared the codes.
Old Nov 13, 2023 | 08:52 PM
trinitony's Avatar
trinitony
I had the same codes and after changing the TB this weekend all the codes were cleared.
OK_R56SMT
Sep 21, 2023 08:32 AM
Gabe3
Oct 20, 2020 08:48 AM
fullmoonguru
Jul 12, 2020 09:18 PM
JacobCW
May 10, 2015 02:50 AM
supercoopers
Jul 11, 2005 02:11 PM
